to needed how
How to needed
Please can someone make a 'how to remove heater vents' the ones to each far side please
what are you planning lol
Cameron UK Wrote:Please can someone make a 'how to remove heater vents' the ones to each far side please
Possibly wrapping, not too sure how it would go though because of the heat?
the trim will just pull off but be very careful and take you time there are about 9 little clips that hold the trim on the vent
start from the inside freeing a bit at a time
tucpal Wrote:the trim will just pull off but be very careful and take you time there are about 9 little clips that hold the trim on the vent
Pictures would be good, hint hint
i have no plans to take it back off at the moment
  Technical (electrical?) info needed for the DVD800 radio and HVAC control panel i.rosca 1 12,156 22:nd-Jan-2019, 09:51:25
  Schematic Diagram needed vagepap 5 7,904 28:th-May-2016, 16:16:30
Last Post: vagepap
  Part number needed Fmcnic 9 11,575 5:th-Oct-2014, 20:22:45
