vauxhall recall
Vauxhall recall
Hi all I just been told by Vauxhall there is a recall do do rust protection around the fuel filler cap.
Hope this helps you out.
isnt that where they drill a hole
Hi not sure I have a hole on mine tho
Yep! They drill the hole inside the fuel can area, fill it with wax and bung it up... Job done
Oh so looks like I got to get mine done they said wait till next service which is November.
Had mine done today, along with some software updates
Here's what the end result looks like
This is mine - what software updates ? Never told me any
[Image: j2McLHo.jpg]
(13:th-Apr-2016, 16:25:31)Daz21 Wrote: Hi all I just been told by Vauxhall there is a recall do do rust protection around the fuel filler cap.
Is the fuel filler cap a recall or a service bulletin, did you receive a letter through the post?
I have just received a recall through the post regarging the second stage remedial work on the cooling fan module, Product safety recall E140752(14-C-073). I had the first stage done (remove battery cover). I believe it involves fitting an adapter wiring harness to the cooling fan module.
I had to ring up and ask also I rang again today asking if there were any more but there's nothing
(14:th-Apr-2016, 17:29:36)sheppy1 Wrote: I had to ring up and ask also I rang again today asking if there were any more but there's nothing
Thanks I'll ask if mine requires it done when I book in for the cooling fan recall.
  VAUXHALL ASTRA 1.7 CDTI FUEL SENDER UNIT 13272601- FUEL ERRATIC GUAGE BELWO HALF TAN caretaker 3 3,911 21:st-Oct-2024, 18:22:15
  Decent Vauxhall specialists? SomePigeon 2 3,215 12:th-Jul-2021, 20:42:12
Last Post: SomePigeon
  ECM "Upgrade" Recall Causing Performance Issue? Black_Cat 4 9,527 6:th-Nov-2016, 22:57:55
  vauxhall paint warrnty evo 2 6,878 19:th-Aug-2016, 21:52:10
Last Post: bhalay207
  Just seen this on my Vauxhall app... bhalay207 2 6,186 5:th-Jan-2016, 07:57:52
  recall tucpal 4 6,671 19:th-Feb-2015, 04:32:38
  Cant fit a vauxhall radio and got no steering controls for connect2? Markt8 4 8,925 18:th-Sep-2014, 14:18:58
Last Post: Markt8
