reverse upgrade bulb
Reverse bulb upgrade
Looney Hi so ive upgraded my tail lights to LED works fine tail light are not on the Canbus however the reverse bulb is and its causing an error does anyone know if there are any plug and play resistor kits for this part of the lighting system as it has a different connector and the bulb is the offset type i cannot see any. I dont want to be cutting wiring and i am using a canbus error but its not pulling enough power clearly thanks.
I have LED's in mine and they aren't on the canbus.
(1:st-Jan-2016, 17:22:06)Rusty2009 Wrote: I have LED's in mine and they aren't on the canbus.
They are on mine unfortunately it a 2010 J SRi it comes up check reversing lamp I may just have to keep a normal bulb in then thanks for reply rusty
Only thing you could do is add a resistor on the Rev light wire which LED bulb did you use (do you have a link)?
(1:st-Jan-2016, 20:41:56)Rusty2009 Wrote: Only thing you could do is add a resistor on the Rev light wire which LED bulb did you use (do you have a link)?
http://www.ebay.co.uk/itm/141191988703?_...EBIDX%3AIT
Similar to the reg plate bulbs in mine...most don't have any issues but mine come up with an error...odd
That's the same bulb I have.
I would suggest a resistor on the Rev light wire then
Mine come up with an error too
  Cd400 to nav500 upgrade. tucpal 265 435,084 31:st-Aug-2021, 19:57:38
  Stereo upgrade options Amazingusername 6 14,592 9:th-Feb-2021, 14:07:41
Last Post: loeb
  Drl bulb holder elliot472 5 7,698 23:rd-Feb-2019, 23:46:27
Last Post: Rocky33
  Wanting to install bluetooth and upgrade CD400 andy2174 14 38,046 1:st-Mar-2018, 20:27:35
  Rear fog light bulb ID jl47 0 5,668 15:th-Dec-2017, 15:24:34
Last Post: jl47
  Rear tailgate bulb Jon3sy 4 6,668 16:th-Sep-2017, 14:41:20
Last Post: Jon3sy
  HID upgrade Dale90 29 26,866 10:th-Aug-2017, 09:33:25
Last Post: Dale90
  Fitted rear led lights, now bulb warning issues twinpipes 3 8,162 27:th-Jul-2017, 21:02:41
Last Post: Hummelshøj
  ECM "Upgrade" Recall Causing Performance Issue? Black_Cat 4 10,159 6:th-Nov-2016, 22:57:55
  Glove box bulb JPW 2 6,391 25:th-Oct-2016, 19:02:58
Last Post: JPW
