suspension funny noise from
Funny noise from suspension
When driving at low speeds gong over uneven surfaces I can hear a kind of knocking as the car moves around. It only happens on bad Road surfaces, seams to come from the left side?
Anti-roll bar drop link ball joint worn.
Don't jack the car up, then try and reach in and grab one, see if it has some play in it.
As above or possibly a drop link, had this on my H
Kevin Wrote:Anti-roll bar drop link ball joint worn.
So don't jack it up?? Where am I looking and what am I looking for?? . Pictures would be great
Don't have any pics, so will try to explain.
To identify the part, turn the steering full lock. Now look at the side with the wheel turned inwards looking into the arch at rear of wheel. You should see the suspension strut. Attached to this just under the spring seat you should see the link. This in turn attaches to the anti-roll bar.
Now you know what to look for, straighten the steering and reach in and grab the link and give it a move about. If you feel a knock/movement, then that is the culprit. Sometimes to feel the movement, if you grab where the link attaches to the anti-roll bar and pull up and down on there it should show up any movement.
Try not to do this with the steering on full lock as it puts too much strain on the link, and can and will mask the movement. Likewise when you jack up the car.
Hopefully some of that makes sense!
http://www.vxoc.org.uk/forum/Thread-Suspension-systems
Have a look at this link the top file is what your after then items 2(anti rollbar) and 4(droplink)
  Astra J 2014 1.6 petrol, dashboard noise help Steve1982 0 1,089 9:th-Sep-2025, 08:39:49
  Astra J 2014. Electric static noise under dash Steve1982 0 1,016 8:th-Sep-2025, 21:22:49
Sad Chirping noise Zaf312 1 1,948 7:th-May-2024, 07:34:19
  High pitched noise (Astra OPC J) maximame 0 7,056 24:th-Mar-2021, 08:34:13
Last Post: maximame
  Electrik brake noise!! blacknik 1 6,809 24:th-Feb-2020, 08:57:02
  Noise when clutch 1/4 depressed 2013 Astra J Galway11 0 10,734 27:th-Jun-2019, 22:40:04
Last Post: Galway11
  Strange noise from passenger side when driving slowly/stationary and just taking off irishastraowner 3 7,838 16:th-Mar-2019, 09:34:36
  Astra J 2.0 cdti noise on cold start up Iaintruten 3 10,712 17:th-Jan-2018, 17:26:31
Last Post: Iaintruten
  Water Noise Sloshing sheppy1 22 33,621 15:th-Oct-2016, 11:16:57
Last Post: andy2174
  Whirring noise richje100 13 24,261 20:th-Mar-2016, 15:32:00
Last Post: Jj0063
