led check strip
Check LED Strip
Hi All Smile
So I'm no electrician but I wanna test if my LED strip works that I plan on using for the footwell lighting before I wire it all up in the car...is there any way for my to do so around the house?
Could jam the wires in the plug socket but something tells me that's a bad idea hahahaha
Do you have a 9v battery?
If so use that.
Nice one! Just half inched one from the smoke alarm for 5 mins seems to work fine! Not as bright as I thought though... Will it be brighter when wired to the cars electrics?
Yes will brighter your only using 9v and the battery could also be low.
You're the man! Cheers Smile Will try and fit them this weekend
  Check Number Plate Lamp Warning mp21 10 16,060 10:th-Nov-2020, 23:33:17
Last Post: Galway11
  Lacking Power - What can I check everson38 3 6,102 10:th-Jul-2019, 10:44:50
  Replacing door check strap robk999 5 10,606 7:th-Feb-2019, 21:27:33
  Remove bonnet strip kippax 8 13,988 27:th-Dec-2016, 19:49:55
  Check License Plate Bulb sheppy1 26 34,708 26:th-Oct-2015, 14:52:23
  Check left drl kfayz 1 4,963 15:th-Apr-2015, 19:50:10
  OEM Led strip headlights upgrade. Astra J Antdawe 18 26,222 17:th-Oct-2014, 18:52:13
