OEM Led strip headlights upgrade. Astra J
I was driving along today and a red astra J pre facelift 59 plate had the new style led strip in the headlight.
Is this an upgrade or where they available from new from the beginning.
sheppy1 - Replies:
Check LED Strip
Hi All
So I'm no electrician but I wanna test if my LED strip works that I plan on using for the footwell lighting before I wire it all up in the car...is there any way for my to do so around the house?
Could jam the wires in the plug socket but something tells me that's a bad idea hahahaha
sheppy1 - Replies:
Chrome Bumper Strip
kippax - Replies:
Remove bonnet strip
Does anyone know how to remove the plastic bonnet strip. Mine has been damaged somehow and I want to replace it.
Many thanks.
Sent from my HTC One M9 using Tapatalk
Jon_es - Replies:
Advice on sun strip
Im looking for something to go as a sunstrip but dont want to intrude on the rain sensors or auto light sensors, any help?
Leady78 - Replies:
Side turning/indicator wiring diagram to help install sequential LED DRL strip.
Hello all,
I am planning to fit/install front sequential LED light strip which has the function of DRL & indicator signals. I need help or advise on how best to do this. Is it best to try and tap into the side panel indicator or the lower front indicator that is next to the fog light?
Any help would be appreciated, I have experience in wiring other lights on the car but this is the first time I have looked at fitting a sequential LED light strip that needs to use the indicators as a addit
