tyre size
Tyre size
Hi guys
I've got my 19" wheels fitted to my car now but need some new tyres ASAP.
They currently have 255/35/19 fitted but everywhere I've looked online says that they should have 235/35/19 on them.
Anyone able to confirm what tyres I should have?
Jordan
Anyone? Need to order some!
Have a look here mate http://www.vxoc.org.uk/forum/Thread-Wheels-and-tyres all tyre sizes are listed.
Yeah I've seen that which says they should be 235/35/19 but I currently have 255/35/19 just wondered if it was a problem to keep the 255's when I order them
Well if you've had no problem with the different size then the choice is upto you.
But you would to inform your insurance company as its classed as a mod.
The tyre change size was done most likely to save a few quid.
it must have done as you need 235 40 19 on the five door
are they genuine alloys
(7:th-Oct-2015, 19:19:27)Rusty2009 Wrote: But you would to inform your insurance company as its classed as a mod.
You don't need to inform insurance about changing tyre size. The fact I've changed wheels yes, but not tyre size.
I work for a specialist insurer Wink
(7:th-Oct-2015, 19:53:44)tucpal Wrote: it must have done as you need 235 40 19 on the five door
Yeah they're genuine, they don't rub so doesn't really matter I guess, il get 235/35/19 or 40 profile depends which is cheaper then.
So what your saying is every broker etc I've spoken to has misinformed me? I totally see there point of view that changing a tyre size is a mod.
In essence, yes.
If you decide to fit a different profile tyre to your car, you do not need to declare it as a modification.
If you are using a 'specialist' broker who says changing the size of a tyre profile is deemed a modification.. you're not using a very specialist insurer.
If you mention it 1st are they likely to say 'yes that will cost more sir' just to get more money out of you?
(8:th-Oct-2015, 17:37:37)dutton84 Wrote: If you mention it 1st are they likely to say 'yes that will cost more sir' just to get more money out of you?
Some may well do. The one I work for (I actually leave tomorrow!) doesn't and hasn't done ever. I've worked there years.
  Gtc 2017 1.4t 120 front brake disc size Nathan191210 2 8,346 25:th-Apr-2020, 07:41:05
  Tyre Pressure Warning Niggle phlyer 4 7,968 23:rd-Mar-2019, 11:39:36
Last Post: andyp
  Tyre sealant Telsun 4 5,628 23:rd-Feb-2019, 13:28:50
  Piper cross size? HarryH 3 5,722 14:th-Jan-2019, 16:15:45
Last Post: Willcbrbikeboy
  Cracked tyre valve with TPMS Craig2305 5 7,713 5:th-Oct-2018, 13:31:48
Last Post: Craig2305
  Alloy Bolt cap size?!?!?! Jhill7168 0 3,917 8:th-May-2018, 19:26:54
Last Post: Jhill7168
  Rear brake disc size Daniel199025 0 5,214 17:th-Sep-2017, 22:15:55
Last Post: Daniel199025
  Wheel size ? Mspencer 4 6,352 20:th-Aug-2017, 09:45:19
Last Post: Mspencer
  Tyre choices 18" wheels andy2174 6 12,724 15:th-Apr-2016, 17:14:13
Last Post: andy2174
  What tire size? Dannydyer 7 8,800 19:th-Feb-2016, 00:29:31
Last Post: Dannydyer
