tyre pump
Tyre Pump
Hey Guys
Just a quick one here... Not really important or related to anything I'm doing but wanted to know of the tyre pumps that you guys have with your cars are built into the car (in the boot somewhere) or are separate and you need to plug them into the cig lighter?
Reason I ask is that we had to use one tonight on my old Corsa D and I found out that it's built into the boot side wall! You pop a cover off and run a long pipe from the boot to the tyre and then turn the engine on and it powers on!
With my astra it's all separate and I have to run a power cable from the cig lighter. Was wondering if this is still the case on the higher trim levels and older models?
Sent from my OnePlusOne
Yes the inflation kit is the same only one type I just got one
Silly question, will my Sri have this or not? I have the spare wheel! Not looked for anything like you're describing.
The VX one is in the loft I have a battery one so much easier.
They are found on cars that don't have the spare wheel but still there handy to have
Built in pump sounds like an unnecessary expense by vx
Fair enough then guys. Just thought it was cool seeing it all built in like that and wished I had it haha
Try wrapping the air pipe back up on the inbuilt one.... Nightmare!
(2:nd-Aug-2015, 10:08:21)bhalay207 Wrote: Try wrapping the air pipe back up on the inbuilt one.... Nightmare!
Ahhhh... Need to do this today for the Corsa... Not looking forward to it now hahaha
It's because it's so long. You end up just jamming it it haha.
(2:nd-Aug-2015, 12:05:56)bhalay207 Wrote: It's because it's so long. You end up just jamming it it haha.
We still talking about the same thing here? hahaha
Are we..... Who knows Rotfl
  Fuel pump needs priming? Amazingusername 3 3,968 21:st-Mar-2021, 20:34:09
  Tyre Pressure Warning Niggle phlyer 4 7,465 23:rd-Mar-2019, 11:39:36
Last Post: andyp
  Tyre sealant Telsun 4 5,308 23:rd-Feb-2019, 13:28:50
  Cracked tyre valve with TPMS Craig2305 5 7,068 5:th-Oct-2018, 13:31:48
Last Post: Craig2305
  Tyre choices 18" wheels andy2174 6 12,077 15:th-Apr-2016, 17:14:13
Last Post: andy2174
  Washer pump dead? richje100 18 22,614 27:th-Feb-2016, 19:54:40
Last Post: richje100
  Tyre size Jj0063 10 11,208 8:th-Oct-2015, 18:06:22
Last Post: Jj0063
