30mm eibach
eibach 30mm
Anyone got them on standard 20`s 245/40R20 will it rub?
[Image: jf944w.jpg]
i had problems with them on my 19.s on the 5 door
they rubbed the inner arch when turning the steering wheel full lock
baz has lowered his VXR with 20inch
but that's only 10mm on the VXR
sure he will give some feed back
thanks mate, ill wait on his answer.
also the vxr use 245/35 as oposed to mine 245/40 so ill assume its even worst.
i am sure it was the larger 235 tyers that were the issue with my 5 door
there are fine on the standard springs but when the car was lowered
i encountered problems with full lock
on the plus side for you i am sure i am the only one who has reported this problem
i am also sure not many GTC owners have lowered on 20 inch yet.
(12:th-Jun-2015, 06:59:16)tucpal Wrote: i am sure it was the larger 235 tyers that were the issue with my 5 door
Yeah ,thats why i rather wait for someone to give some feedback otherwise ill just get some vxr wheels with the lower tyre wall, and then drop it 30mm as ive seen lots of vxr lowered 30mm without any rubbing issues.
  Eibach Pro Kit AshleyC 1 4,821 1:st-Mar-2017, 08:22:19
  30mm springs mrtc 11 16,164 5:th-Nov-2016, 15:49:20
Last Post: Luciano
  eibach wheel spacers tucpal 8 11,367 23:rd-Aug-2014, 22:32:44
  Eibach Lowering Springs MattC3156 30 27,514 19:th-Mar-2014, 02:14:41
