springs 30mm
30mm springs
I know the 40mm eibach springs are supposed to be the best but 40mm seems a bit much for me,
Anyone heard of these springs
http://www.gnjmotorsport.com/search-by-c...dti-10-09/
Quite common brand and reasonably popular, do coil overs and electronically adjustable dampers etc etc , German origins I believe so probably good quality too.
TBH I think anything over 10mm is just too much for the J.
Even on 17s?
I run 19's got some 18's it's more about ground clearance.
I have no issues with eibachs and 17s on mine. I have prefacelift J too.
(14:th-Jun-2016, 17:52:40)mrtc Wrote: Even on 17s?
It doesn't matter what the wheel size is, the diameter should be the same, obviously though the larger the the tyre the wider it is generally. Personally I don't think the 30mm or 40mm is too much, you would have to take into account speed bumps, pot holes etc when driving.
I would stick to Eibachs for lowering on the J though because it's quite a hefty hatchback, that and it is tried and tested, but I don't think they do a 30mm drop for the 5dr. Saying that though, I have read on nemerous forums where different make springs have been used and can't remember reading any complaints or horror stories, and people aren't usually backwards when it comes to slating product ont tinterweb.
(14:th-Jun-2016, 06:30:55)mrtc Wrote: I know the 40mm eibach springs are supposed to be the best but 40mm seems a bit much for me,
Looking for a set of lowering springs myself always have fitted Eibachs to my other Vauxhalls in the past (but only the 30mm lower) Just wondering what choice of springs did you eventually go for & if so what size of drop?
Nothing yet lol
ok guys everytime i search for lowering springs all i get is the Eibach pro system thats with shockers can i not just change the springs for a lowering set on my astra j 2.0 cdti ecoflex elite 2011 or do i have to fit both anyone out there can help ?
(16:th-Sep-2016, 11:29:36)Luciano Wrote: ok guys everytime i search for lowering springs all i get is the Eibach pro system thats with shockers can i not just change the springs for a lowering set on my astra j 2.0 cdti ecoflex elite 2011 or do i have to fit both  anyone out there can help ?
Here you go, springs only... http://www.tunershop.co.uk/Eibach_spring...87937.html
finally got the spring fitted the car now looks really cool 40mm was the right way to go, once it bedded in it went even lower, now got to keep away from speed bumps
  Lowering springs identify front rear martinpe68 1 4,170 12:th-Sep-2021, 15:22:37
  VXR lowering springs hooper 3 6,852 5:th-Apr-2020, 08:30:10
  SRI springs Rusty2009 12 14,218 9:th-Mar-2020, 11:09:10
Last Post: Gordo
  Flex ride shock absorbers and springs ? Raf7007 6 11,489 15:th-Mar-2017, 08:37:48
Last Post: vocky
  Lowering Springs jamoes009 2 5,149 10:th-Mar-2017, 21:42:56
Last Post: stigeye
  Lowering springs damage CV joints? newredgtc 4 7,163 21:st-Oct-2016, 13:29:54
  Looking info on induction kit dump valves and lowering springs Deano1991 1 7,608 26:th-Jul-2016, 18:11:20
Last Post: WoZLinGToN
  Springs help! newredgtc 1 4,329 1:st-Jul-2016, 12:38:28
  eibach 30mm ilovetechnopt 4 7,571 13:th-Jun-2015, 15:24:34
Last Post: ilovetechnopt
  Lowering springs... LiamTurner 1 5,345 2:nd-Jun-2014, 21:49:16
Last Post: J1ODYA
