remove chrome
Remove Chrome
So as much as I love bits of chrome here and there and I won't stop until I have chrome window trim! I'm thinking that my chrome handles aren't that good anymore and might remove them.
Anyone got any idea if the 3M tape will take the paint off with it when I try to remove it? Is it tougher to get off that the badges?
is it them cheap tacky that Tucpal had fitted?
http://www.ebay.co.uk/itm/vauxhall-opel-...339db65698
If so I would say some heat and all should be fine but Tucpal will no doubt tell you if I'm wrong Lol
Yeah they're the ones....hahaha. They look tackier the more I look at them. Take it tucpal thought the same thing? :P
Just in the middle of removing it now and it's coming off easily Smile just used how water to loosen the glue, string to pull it away from the car a bit and then a trim removal tool to get behind it and yank it off!
i removed them after a year just heat them up and pull them off but they were stuck very well
and no damage to the paint lots of heat is the trick
Yeah did just the thing but with hot water and they came off easy enough. Take it your car doesn't have the chrome inserts in the handles then?
no there just color coded
Same as mine then..sure I'll be able to do the chrome door trim but those handles may be tricky!
the factory chrome handles are built in so if you were after them you would have to swap them over
rusty has the factory chrome ones on his car
Yeah I found that out too, have been on eBay looking for some but gonna be next to impossible to find some in my colour and a set of 4 too!
they are rare
I'm still after a painted set in carbon flash, I like the chrome but think the little bit on the handle is tacky.
Shame you don't have the same colour car as me and we could swap :P ha
  Blank/Remove EGR sheppy1 17 20,045 9:th-Jul-2019, 10:47:03
Last Post: Youngy93
  centre console / gearstick slider how to remove? lacesoutdom 3 6,589 10:th-May-2018, 07:41:01
  how to remove the DIFFUSER TRIM opelastra 0 4,709 8:th-May-2017, 13:50:52
Last Post: opelastra
  Remove bonnet strip kippax 8 12,894 27:th-Dec-2016, 19:49:55
  How can i remove n/s boot liner spybot 2 8,341 24:th-Jun-2016, 12:27:16
Last Post: spybot
  Painting Chrome bruce_19 5 7,879 15:th-Mar-2016, 09:44:01
Last Post: bruce_19
  Chrome Window Trim sheppy1 30 30,049 23:rd-Oct-2015, 16:30:37
  Window switch chrome Rusty2009 25 20,743 8:th-Sep-2015, 10:57:44
  Remove Leather Seat Leg Support sheppy1 5 8,179 8:th-Jun-2015, 21:01:40
  Chrome Headlights sheppy1 4 6,533 1:st-Apr-2015, 07:44:34
