springs sri
SRI springs
Am I right in thinking that the SRI springs are 10mm shorter than the other models?
Only on engines bigger then the 1.4 I believe
As Whelan say's Also I believe they are stiffer as well.
been offered a set off a 2.0CDTI for £67 just thought it might give the drop I'm looking for.
I've got a set of standard VXR springs in my garage
cornishtaz Wrote:I've got a set of standard VXR springs in my garage
Is that an offer Lol would they be ok on the 2.0CDTI 5 door and what drop Lol
they probably would work on the 2.0 cdti rusty and would be better than the SRI springs
but as side 10mm lower and sifter with the SRI but you wont really see a big difference
but if you do not want to go to low it may well be a good option over the standard springs
Yeah I've really been thinking and I thought a 30mm drop would be ok but the more I think about that it would be too much some the humps etc round my way are high enough that you can scrape on them even at 5MPH.
So a 10mm would be safe and it will close the gap abit (plus with the "lifetime warranty" they would be too thick too notice)...
What do you think on the price £67 posted for all 4 springs so far?
as long as they are from a 2.0 cdti sri then very good
The VXR springs sit 15-20mm lower than standard GTC springs
yes rusty i do have to be careful over speed bumps
with the 40mm drop still a nice drive but the odd pot hole
can make the car bump but still much better drive than the standard springs
Got a full set here shocks and springs make me an offer
Could do with them gon
Has anyone got a a full set of vxr springs at all?
  Lowering springs identify front rear martinpe68 1 4,140 12:th-Sep-2021, 15:22:37
  VXR lowering springs hooper 3 6,833 5:th-Apr-2020, 08:30:10
  Flex ride shock absorbers and springs ? Raf7007 6 11,437 15:th-Mar-2017, 08:37:48
Last Post: vocky
  Lowering Springs jamoes009 2 5,117 10:th-Mar-2017, 21:42:56
Last Post: stigeye
  30mm springs mrtc 11 17,191 5:th-Nov-2016, 15:49:20
Last Post: Luciano
  Lowering springs damage CV joints? newredgtc 4 7,104 21:st-Oct-2016, 13:29:54
  Looking info on induction kit dump valves and lowering springs Deano1991 1 7,564 26:th-Jul-2016, 18:11:20
Last Post: WoZLinGToN
  Springs help! newredgtc 1 4,304 1:st-Jul-2016, 12:38:28
  Lowering springs... LiamTurner 1 5,329 2:nd-Jun-2014, 21:49:16
Last Post: J1ODYA
  Front springs Tottybye 26 21,636 12:th-Apr-2014, 15:21:37
Last Post: cornishtaz
