clutch air question con pully
Air con pully/clutch question
Anyone on here had any luck with servicing the pully/clutch on a 2.0 cdti?
Had it into a garrage today who want to replace the whole pump for £500
But can't get a part until next week.
Have a long drive this weekend (over 1000 miles) and I don't fancy being without air conditioning
The center of the pully tries to catch when air conditioning switched on so I'm pretty confident it's the clutch mech thst is gubbed
Not that I'm aware of.
Hi i think im having a similar issue on my 1.4t gtc or so the mechanic says its something to do with the aircon clutch? But needs to be stripped down and checked! Basically can hear a slight squeel as the car is running and then when aircon is on it gets alot louder. Its almost as if it makes the whole engine shake! Air con works fine though to my knowledge..
Do you have any similar issues like this or is your air con not working?
  Auxiliary Belt failure - cam belt change question David` 8 3,917 27:th-Aug-2020, 17:57:38
  2016 Astra K GTC Malfunction Light Question ed-b 2 4,250 28:th-Oct-2018, 03:48:53
Last Post: ed-b
