How to stop Smelly air-con
I can't take the praise for this one as such, although mine is slightly different to the how to guide available elsewhere on the Internet.
Here goes: For a few months I have had a bad smell from the air con after it has been turned off, especially the day after. I understand this to be a build up of bacteria within the system, but I hadn't realised how cheap and easy it is to resolve.
Firstly, buy a can of this [ATTACH=CONFIG]242[/ATTACH] which cost me £3 from Asda. I understand it has been
tucpal - Replies:
HOW TO TOP UP AIR CON.. ASTRA J
[align=center][Image:
This How to Covers How to Top up the Air Conditioning on the Astra J/GTC.
You can Buy Air Con kits from Halfords or Online there Basically all the same
The Kit cost is Around £60.00 with the Charger Adapter and the Top up Canister
You can Get £10.00 Back on the Canister after use so after Purchasing the Charger Adapter
The Next Time you Top up it will only Cost £30.00 for the Canister
The Charger
B393B-04 air con issue
I took my car to the local garage to charge the AC is it does not get cold but i was told it was full. They the plugged it into the computer and it came up with the error below and could not fix it:
B393B-04 air conditioning compressor valve control circuit - open
A quick google says its a possible short, can anyone give me an idea as to what to look at, i have a meter to check shorts but not sure what loom or where to look.
Air con pully/clutch question
Anyone on here had any luck with servicing the pully/clutch on a 2.0 cdti?
Had it into a garrage today who want to replace the whole pump for £500
But can't get a part until next week.
Have a long drive this weekend (over 1000 miles) and I don't fancy being without air conditioning
The center of the pully tries to catch when air conditioning switched on so I'm pretty confident it's the clutch mech thst is gubbed
Tidyk - Replies:
Air con
Error code 4.4b393b on Vauxhall Astra gtc engine fan running all the time on full even if air con off dealer saying I need new air con unit expensive but other have said it a valve at help appreciated
Air Con Hiss
My air con has started to make a hissing noise when it is switched on and is no longer cold. Is it worth trying to do a top up or is it likely I have a leak?
It’s a 64 plate and done 46k miles. I’ve never had it topped up before.
Marc_81 - Replies:
Air Con Pipe ID
I have a leak in my Air Con system coming from the high pressure/low pressure pipes. Having trouble ID'ing the part numbers. Its a 2014 2.0 CDTI SRI, i've looked on ebay and these used ones look the right ones but they have no part code for me to check new prices. Can anyone help?
Much appreciated
Marc
[Image: https://i.ibb.co/SXMRzVG/s-l1600.jpg ]
