Welcome, Guest |
Latest Threads |
2010 Astra J - Cooling Fa...
Last Post: Madal101_uk
19:th-Dec-2024, 22:04:08
» Replies: 3
Request heated steering w...
Last Post: emilalexandrubarb
19:th-Dec-2024, 20:16:39
VAUXHALL ASTRA 1.7 CDTI F...
21:st-Oct-2024, 18:22:15
» Replies: 3
Hello from Germany
Last Post: koxaz_nostraz
21:st-Jul-2024, 08:34:11
» Replies: 5
Opel OPC Seat Wiring Diag...
20:th-Jul-2024, 11:04:11
Old member returns
Last Post: Тania_D
20:th-Jul-2024, 11:03:28
» Replies: 3
Oil Temp and pressure sen...
Forum: Retrofit How-to's
Last Post: milozic
16:th-Jun-2024, 16:50:23
» Replies: 4
Have you ever thought abo...
Forum: Chris Knott Insurance
21:st-May-2024, 17:22:04
Help Please :(
16:th-May-2024, 18:49:34
Astra remap
Forum: Members car's progress threads
Last Post: Astragtc1282
13:th-May-2024, 17:38:11
P0128 2 weeks after replacing temp sensor |
Posted by: JonathanLondon - 2:nd-Aug-2020, 16:18:15 - Forum: Vauxhall General
- Replies (4)
I have a 14-plate 1.6 Astra Auto.
Recently got the "AC Off Due To High Engine Temp" warning, and an OBD II dongle said it was a P0128. At the same time the temp gauge went to minimum. Checked under the bonnet and the fan wasn't running even though we watched the coolant temp run up past 90C.
I'm no mechanic, but my local independent garage swapped out the engine temp sensor, topped up the coolant, cleared down the error code, and everything was back to normal. Indeed after driving home from the garage, the fan was running and the coolant was around 80C.
Two weeks later, and the warning has come on again, on the same journey at the same point (about 20 mins from cold). I doubt the new sensor (genuine Vauxhall part) has failed. One additional clue is that on both occasions, the car had been washed a few hours earlier, but I really doubt that it's water ingress causing the problem.
My guess is that may be there's a loose or damaged wire, and that replacing the stat was a temporary fix. The car has done less than 30,000 miles.
Any clues? Torn between taking it back to the local (friendly and very helpful) independent garage, or taking it to Vauxhall (which will be difficult as I am avoiding public transport due to the virus).
Thanks!
Boost gauge. |
Posted by: Nubby - 29:th-Jul-2020, 22:21:47 - Forum: Members car's progress threads
- Replies (1)
Just installed a boost gauge in my astra J 1.6 turbo. I'm far from a mechanic but managed with help from youtube. Anyone stuck on theirs give me a shout and I will try and help.
Check Number Plate Lamp Warning |
Posted by: mp21 - 24:th-Jul-2020, 10:59:37 - Forum: Astra-J/GTC
- Replies (10)
Replaced both blown bulbs this morning and are working fine but the "Check Number Plate Lamp" error is still coming on when ignition turned on. Any ideas?
front brake discs |
Posted by: bgb65uk - 22:nd-Jul-2020, 12:22:14 - Forum: Mechanical
- Replies (4)
could anyone tell me what size discs i need for the front of a 2014 gtc 1.4 t,i ordered a pair from a reputable supplier just to find they where too small ,, advice please
Navi 950 retrofit to Buick Encore |
Posted by: vibalt - 20:th-Jul-2020, 23:37:44 - Forum: Retrofit Research
- Replies (3)
Hello everybody,
I installed the navi 950 in the Buick encore, reprogrammed the EEPROM with the Buick encore VIN and everything went great (head unit works fine). After leaving the car locked for a while and turning on the head unit again, there is no sound at all even turning signals or open door sounds dissapear.
Can anyone help to solve this problem?
Newbie |
Posted by: Nubby - 19:th-Jul-2020, 13:11:24 - Forum: Introduction Area
- Replies (1)
Hi, I'm Dave, I have a 2014 astra J turbo. Looking for general advise and support as I will be doing all mechanical work myself. Thanks in advance
