seat belt buckle rear
Rear seat belt buckle
I'm going to retrofit the rear seat belt buckle with sensors,
I've ordered both the buckles cost £29.00 posted as opposed to £110+.
I have the wiring diagram just can't seem to locate the terminals for it so if anyone can help that would be good, even if you know what other Vauxhall car it's fitted and where it is I can go up the scrappy and get one.
Connector Part Information
Harness Type: Body
OEM Connector: 19151247
Service Connector: 13316188
Description: 54-Way F 0.64 Series, Sealed (YE)
i dont think the other end off the loom will be in the side harnesses
that run along the sill,s so i would just plug them in to the seat belts and then run the wires
up front to were they go to
also is there a fuse involved
No there's no connections in the side hence needing the terminals.
it takes the ground off the pasanger front one and the positive from the module.
I would just cut the connectors of the buckles and use male female bullet connectors it will save you cash buying the correct connector them slice in to the front ground and get a pin for the module then programme it in
That's what I'm after mate pins for IRS module I've got the connectors for the buckles so that's no problem, I did pop up the scrappy this morning (No J's in but I couldn't find anything on the other Vauxhalls in the yard)
You will have to take a pin out and have a look
Rusty does your front passenger seat bong/alert when the seat is occupied but the seat belt is not used?
Yes and the driver seat. Got a light by the centre screen for front passenger and a light on the dash for driver and if you go above 5MPH it bongs at you.
Going to see if I can fit them tomorrow.
Ah on mine it only does it for the drivers seat
But you have a GTC VXR
Yup I just assumed it was cost saving as the elite I had covered all belts.
Yeah they did away with the rears on the 5 door I want them as my youngest loves undoing her bothers seat belts.
The Terminals for the IRS are not available for general sales as it is a proprietary product.
So I've messaged everyone on eBay who is breaking a J or a Sig to ask if they have the connector, so far only one has said they should have it and will look today for me the rest say no.
  Front & Rear Park Pilot Andy_GTC 17 21,324 26:th-Dec-2020, 23:03:44
Last Post: Baich
  Rear camera fit on Opel astra sports tourer info ;) Alienbv 24 30,525 26:th-Dec-2019, 13:00:29
  electrical rear windows Maniacu 12 13,097 19:th-Jul-2019, 12:27:57
Last Post: Maniacu
  Dimming Rear View Mirror MoosaM 1 5,955 21:st-Feb-2017, 08:05:31
  Bi-turbo seat look Rusty2009 8 13,357 12:th-Apr-2014, 17:36:31
