rattles amp squeaks
Squeaks & Rattles
Hope this might help some of you.
Symptoms - Squeaks and Rattles
Rattle Coming From the Side Rail
Rattle Coming From The Side Rail
[TR]
[TD]Checks[/TD]
[TD]Action[/TD]
[/TR]
[TR]
[TD]Check the brake lines.[/TD]
[TD]
Tap lightly on the brake lines and listen for a rattle.
Install plastic tie straps to secure the brake lines tightly together.
[/TD]
[/TR]
Rattle Under Vehicle at Higher RPM
Rattle Under Vehicle @ Higher RPM
[TR]
[TD]Checks[/TD]
[TD]Action[/TD]
[/TR]
[TR]
[TD]Check for heat shield contact with the underbody.[/TD]
[TD]Raise the vehicle and perform a visual inspection.
Bend the heat shield slightly to gain clearance from the underbody.
[/TD]
[/TR]
Thump From Rear of Vehicle on Bumps
[TR]
[TD]Checks[/TD]
[TD]Aciton[/TD]
[/TR]
[TR]
[TD]Check for a properly secured spare tyre or tyre repair kit in the rear compartment.[/TD]
[TD]Open the rear compartment and perform a visual inspection of the spare tyre or the tyre repair kit and the tools.
Tightly secure the spare tyre or the tyre repair kit and all tools.
Perform a road test to verify that the noise is eliminated.
[/TD]
[/TR]
Glass Knock Coming From the Rear of the Vehicle When Driving Over Bumps
[TR]
[TD]Checks[/TD]
[TD]Action[/TD]
[/TR]
[TR]
[TD]Check for an out-of-adjustment hatchback catch.[/TD]
[TD]Test drive the vehicle in order to verify this condition.
Loosen the catch nuts and adjust the catch downward.
[/TD]
[/TR]
Rattle Coming From Door
[TR]
[TD]Checks[/TD]
[TD]Action[/TD]
[/TR]
[TR]
[TD]Check for rattling electrical connectors inside the door trim panel.[/TD]
[TD]Tap on the trim panel and listen for a rattle.
Remove the trim panel and wrap foam padding around the connectors as required.
[/TD]
[/TR]
Squeak When Operating Doors
[TR]
[TD]Checks[/TD]
[TD]Action[/TD]
[/TR]
[TR]
[TD]Check for a lack of lubrication of the door hinge pins.[/TD]
[TD]Operate the doors and listen for squeaks.
Lubricate the door hinge pins with light oil and coat with lithium grease.
[/TD]
[/TR]
Squeak Coming From Console When Shifting Manual Gearbox Condition Occurs In Cold Weather with a Cold Engine
[TR]
[TD]Checks[/TD]
[TD]Action[/TD]
[/TR]
[TR]
[TD]Check the manual transaxle control lever lower boot.[/TD]
[TD]Move the control lever between gears and listen for squeaks.
Remove the floor console and replace the lower shift boot or apply talcum powder to the lower shift boot.
[/TD]
[/TR]
Buzz From the Left Side of Instrument Panel
[TR]
[TD]Checks[/TD]
[TD]Action[/TD]
[/TR]
[TR]
[TD]Check for vibration of the fuse box cover against the instrument panel side trim.[/TD]
[TD]Tap on the cover with a finger and listen for a buzz.
Apply felt pads to the side trim where the cover makes contact.
[/TD]
[/TR]
Squeak Coming From Instrument Cluster Trim Plate
[TR]
[TD]Checks[/TD]
[TD]Action[/TD]
[/TR]
[TR]
[TD]Check for rubbing the cluster trim plate on the instrument panel.[/TD]
Remove the instrument cluster trim plate and install felt tape to the edges.
[/TD]
[/TR]
Very use full well done
  Trim rattles tucpal 81 39,698 13:th-Feb-2018, 23:14:19
Last Post: Iaintruten
richardt (24:th-Feb-2024, 17:34:05)
