relay accessory passenger location
Passenger accessory relay location
Pouring over the wiring diagrams for the problem I have, tracing the current path to the front accessory socket, it runs via F1 and F6 via the passenger accessory relay.   Haynes is a bit light on relay info TBH.
There is power at F1, although there is no current flow, as though the circuit is open, but shorted to earth via my tester its there.  Done same at F6, nothing.  To my mind this suggests the relay is poss duff, My Haynes says the relay is in the passenger fusebox but there's nowt but fuses.  Is it on the back?  The FB looks as though it swivels out...
Phlyer Phil
Head In The Clouds
Mind In The Gutter
On the top, Have a look here.
https://vxoc.org.uk/forum/Thread-Fuses?p...4#pid11164
  Next relay question... phlyer 1 4,089 21:st-Dec-2023, 08:32:58
