bonnet j help won open astra t
Astra j bonnet won't open help
Help bonnet won't open . The leaver goes all the way with no resistance. Bonnet does not pop up .
Get someone to pull the lever as you put pressure on the bonnet, mate. If that doesn't work, look for the cable that attaches to your bonnet release lever. It's out there in the open, no need to remove any plastics. You can pull on it hard with some pliers and that should get you sorted. Once you (hopefully) get it opened, take a look at the latch mechanism and springs. I wouldn't be surprised if it's gunked up and given the weather lately - frozen stiff as a result. You might try cleaning/lubing it as a long-term fix.
Thanks for the reply. I have literally tryed everything over the last week . So it's off to vauxhall so they can sort it .
  Astra 1.6 CDTi Turbo Issues P2598 shaky411 1 2,541 12:th-Sep-2021, 15:24:05
  Vxr bumper on 5 door Astra j Sh4rk2007 10 8,077 6:th-Jun-2021, 18:25:04
Last Post: jeniferbitcoin71
  New Battery for Astra J 2013 reg 1.7 diesel Galway11 6 3,585 13:th-May-2021, 11:38:55
  Astra J 1.4T Exhaust help sammpennington 1 3,807 12:th-May-2021, 14:29:50
Last Post: azajus
  Astra j gtc modifications BillyBryan 2 1,898 9:th-May-2021, 17:15:36
Last Post: Spaghetti
  Astra J Fault code reader suggestions Euroshopper 1 2,030 22:nd-Feb-2021, 08:50:12
  Astra J GTC PDC bracket milozic 5 2,505 2:nd-Feb-2021, 09:39:35
  Astra J Rear Bench Seat Clip. MrScottyMan 1 1,823 24:th-Jan-2021, 14:44:22
  Astra J workshop manual Euroshopper 1 1,965 9:th-Jan-2021, 08:09:36
  Astra J Keyfob range Arkanggel10 2 2,062 16:th-Dec-2020, 21:40:09
Last Post: Multiskilled
