op com vehicle service and soon
Service Vehicle soon and Op-com
Hi all.
i've got on my dash the svs message, i took the car to a garage for a diagnose, and it came out with code P0672, glow plug on cilinder 2 faulty.
I ordered op-com, and when i read codes i got the same code (P0672) and 5 others.
can anyone tell me if the other codes are related to the faulty glow plug, or if they mean that more issues are going on?
thanks
I would say clear the codes and see what comes back as some of them could be old errors.
Have you checked through the fault code list thread?
https://www.vxoc.org.uk/forum/Thread-Fault-Codes
As John said it could be worth clearing the codes and seeing which ones come back.
DTC P0398 00: Cylinder 1 Pressure Sensor Circuit High Voltage
DTC P03AC 00: Cylinder 3 Pressure Sensor Circuit High Voltage
DTC P03B6 00: Cylinder 4 Pressure Sensor Circuit High Voltage
DTC P03A2 00: Cylinder 2 Pressure Sensor Circuit High Voltage
DTC P0672 00: Cylinder 2 Glow Plug Control Circuit Malfunction
DTC P0396 00: Cylinder 1 Pressure Sensor Performance
yes, i did Rusty2009, my doubt is related to the garage, where only the P0672, came in the machine. Or Op-com is more powerfull than general machines?
i ordered already 1 glow plug (because my car uses the expensive ones, with sensor? i will get it replaced and see what comes after.
thanks
  'Service Vehicle Soon' on display Loddy Jeff 10 4,323 12:th-Oct-2020, 12:51:00
  ESP service message, erratic fuel range figures on trip computer mpotsb 2 2,717 7:th-Sep-2020, 12:04:29
Last Post: mpotsb
  "Stop Vehicle Immediately Engine Has Overheated" Advice appreciated please Dennis S 25 39,252 30:th-Aug-2020, 13:56:18
Last Post: Rgotts00
'service vehicle soon' Ssss 1 1,829 12:th-Aug-2020, 07:56:03
Service vehicle soon??? k1ckboxer 3 2,273 10:th-Aug-2020, 14:53:25
Last Post: Ssss
  service parking assist and tpms not working kevinmcken1404 3 2,836 18:th-May-2020, 10:09:32
  service vehicle soon stevedemp23 2 2,502 16:th-Jan-2020, 08:11:31
Service Bulletin syscleaner 2 2,474 1:st-Sep-2019, 18:26:13
Last Post: syscleaner
  Astra GTC service vehicle soon Beechy 9 10,050 25:th-Feb-2019, 15:53:15
Last Post: pat100
  Technical Service Bulletin 3141 ECU update Tony Davis 2 3,421 4:th-Feb-2019, 15:15:49
Last Post: Tony Davis
avenue17 (31:st-Jan-2024, 08:04:41)
