radiator j fan plate astra 13 sri
Astra J SRI 13 Plate - Radiator Fan
Good evening guys,
looking to see if anyone can help with a problem i have with my 13 plate Astra J SRI,
For a while the radiator fan was staying on (common issue i know), i didnt do anything about it until recently,
I have replaced the thermostat and housing, the temperature sensor, checked that all the fuses are intact, removed the sensor from the air filter and still nothing from the fan,
I kept getting the message "coolant level low - add Coolant" i replaced the expansion tank and now ok,
I have seen that there could be an issue with the relay? unsure which one it is as its not mentioned in the handbook,
I have also ordered test leads to see if the fan works when i connect to the battery...
coming a bit unstuck now and just wondered if anyone had any other ideas i could try before i put it into the garage?
Gavin
This may help with the relay looking up.
https://www.vxoc.org.uk/forum/Thread-Fuses
(9:th-Jul-2020, 07:18:49)Rusty2009 Wrote: This may help with the relay looking up.
Many Thanks, ive ordered new relays so will try that out... if not i will test the fan and see if its that,
Thanks for the reply, will report back,
  High pitched noise (Astra OPC J) maximame 0 4,521 24:th-Mar-2021, 08:34:13
Last Post: maximame
  Gear Knob issue (Automatic 2014 Astra GTC) DC23 1 5,342 22:nd-Feb-2021, 08:08:37
  Astra J. Can a tyre valve be replaced without replacing the TPMS? benawhile 2 3,874 5:th-Aug-2020, 12:33:14
Last Post: benawhile
  Astra GTC auto gear knob replacement Jayrich872001 12 20,576 22:nd-Jul-2020, 12:21:46
Last Post: DC23
  Astra J 1.6 CDTi increased fuel consumption _Mita 2 5,499 1:st-Mar-2020, 22:27:38
Last Post: _Mita
  Astra ST 1,6 CDTi, error code P0181 claymansvk 1 2,863 20:th-Feb-2020, 19:32:31
  shock absorber noises astra j blacknik 1 4,798 10:th-Feb-2020, 08:34:15
  Noise when clutch 1/4 depressed 2013 Astra J Galway11 0 8,064 27:th-Jun-2019, 22:40:04
Last Post: Galway11
  Astra j radio / display problem Trublu24 6 16,532 1:st-Feb-2019, 08:38:04
  Astra GTC CD 600 Blutooth will not delete devices harrykelly9 2 5,445 24:th-Oct-2018, 21:52:47
Last Post: harrykelly9
