upper ipc speedo upgrade display
IPC Upper Display Speedo Upgrade
Hey everyone,
I've got an Astra J Excite with the lower IPC display. I wanted to buy a unit off eBay and fit it myself but ive done some research and undertstand it will need programming. I called vauxhall and asked if they could program it for me if i was to fit it and they said it's not possible, but I've read in the workshop manual that it could be programmed with the SPS programming device.
Hi so a dealer will not be able to do it as it officially can't be done.
I spent weeks figuring out how to do it so it is possible but not simple.
You can't just grab a set off ebay and think you can program it and it'll work there is alot more involved.
I've seen your PM today and will be replying (I've just been really busy the last few weeks & not had a lot of time spare).
  cd 400 upgrade to navi 600 need help goose9029 6 9,742 14:th-Feb-2024, 07:52:16
  Insignia odometer is locked mileage no display Robsterw1980 1 4,513 22:nd-Feb-2021, 08:14:20
  parking and cluster upgrade Maniacu 5 13,552 8:th-Sep-2019, 13:06:46
Last Post: andre_rf
  Navi radio and larger instrument display changing gazz292 54 96,388 28:th-Apr-2018, 10:47:52
Last Post: gazz292
  Icebox users.. what does the display look like behind the trim panel? gazz292 2 8,841 16:th-Apr-2018, 12:29:56
Last Post: gazz292
  Advice needed regarding HID upgrade for a 2010 Insignia i.rosca 11 19,021 17:th-Dec-2016, 15:55:57
Last Post: i.rosca
  Colour Display in CD400 sheppy1 14 18,632 22:nd-Jun-2016, 22:42:56
Last Post: stigeye
  Speedo display bhalay207 18 17,589 22:nd-Sep-2015, 16:43:18
Last Post: bhalay207
  Display question? Retrofit! Alienbv 6 10,494 14:th-Jul-2015, 10:54:43
  Brake & Disc Upgrade Turner_SRi 23 26,897 21:st-Sep-2014, 16:05:24
Last Post: JohnL
obsidian (31:st-Aug-2025, 20:35:15), dbk2ii (23:rd-Sep-2025, 20:49:30)
