Speedo display
Speedo
Looking for a bit of info. Thinking of having a go at swapping out the leds in the speedo but just wanted to know if i got a second-hand one of ebay would i be able to do the led conversion and then just fit it back into mine, and would it work?
Speedo panel
Anyone got a speedo panel with the small display on. Doesn't need to be working as its only for soldering practice removing the display panel
yazza54 - Replies:
Speedo drive?
guys
Does anyone know where the speedometer sensor is on my car? It's a 2.0 CDTI GTC 2012... I have a bouncing speedo and ABS/TC lights on. Not ideal with winter drawing in. Clearly all the problems are linked, but I can't seem to find a speed sensor on the box, unless the wheel speed sensor drives the speedo as well as work the ABS/TC?
Speedo
Hi guys and girls
I’ve started you use the motorway quite a bit lately and I’ve noticed if I want to go 70mph the speed on the clocks must be 76 mph is this common or do I need a software update or something
AlanMac - Replies:
Speedo stopped working
Hi, Had brakes all around and gearbox oil changed yesterday (all good) but when I got in the car today the speedo and digital readout of speed was not working. The odometer is AOK. Could something have been knocked of or similar?
BL25 - Replies:
IPC Upper Display Speedo Upgrade
Hey everyone,
I've got an Astra J Excite with the lower IPC display. I wanted to buy a unit off eBay and fit it myself but ive done some research and undertstand it will need programming. I called vauxhall and asked if they could program it for me if i was to fit it and they said it's not possible, but I've read in the workshop manual that it could be programmed with the SPS programming device.
[attachment=1104]
[attachment=1105]
