f40 gearbox oil amount
F40 gearbox oil amount
  1. Anyone no  how much gearbox oil the f40 takes
https://www.vxoc.org.uk/forum/Thread-Lub...ol-Engines
or
https://www.vxoc.org.uk/forum/Thread-Lub...el-Engines
on the vxr it's recommended to use 2.4 litres, normally 0.4 litres remains in the gearbox during an oil change - so just add two full litre bottles
Thanks for that .loads of different figures about on this was told 1.9 liters for f40 think I will drain it and see what comes out
Normally you have 2 bungs a fill and a drain, it used to be you drain it through the drain bung refit it the fill through the fill bung untill it starts to dribble out and hey presto you have the right amount of oil in. I don't know if this has changed though
Hasn't it got an oil level plug where you fill it until it piddles out?
No its got drain at bottom and fill on the top
F40, ive read 1.8, 1.9 and 2.0 put in.
Im going for Millers oil 75w90 instead of 75w85, prob 2 full bottles (2L)
There is a thread with info on how much oil you will need.
just bouught 2 bottles of this:
https://www.demon-tweeks.com/uk/millers-...il-780844/
I think they have priced it wrong as its 13 quid everywhere else!
20 quid 2 bottles delivered
GL-4 for the F40 box
I put 2.4L in mine but did jack it up to drain it all out.....
  2.0 CDTi Auto Gearbox Oil Change Dennis S 0 1,594 13:th-Aug-2021, 14:29:25
Last Post: Dennis S
  Gearbox whine m32 Nathan191210 1 1,564 22:nd-Feb-2021, 09:18:27
  2014 Astra 2.0L 165 HP F40 gearbox quantity of oil?? Kpal11 3 3,332 12:th-Jan-2020, 16:38:41
Last Post: Kpal11
  Gearbox Oil drain plug? shabba 13 9,358 10:th-Jan-2018, 11:59:11
Last Post: stigeye
  Gearbox Oil Change? doug143 0 3,478 14:th-Jan-2016, 21:05:49
Last Post: doug143
hursty (20:th-Jun-2023, 11:22:37)
