28:th-Feb-2019, 21:11:34
Have got a set of 205/55/r16 snow tyres and i want to put them on my 14 astra elite what rim size do i need to look for. thanks
wheel rims |
wheel rims
1:st-Mar-2019, 11:49:41
r16 means the tyres are 16" in diameter, so you'll need 16" wheels.
1:st-Mar-2019, 21:58:52
does it matter which 16 rims as they are on vectra alloy rims at the moment
4:th-Mar-2019, 12:09:53
(1:st-Mar-2019, 21:58:52)Qaranc Wrote: does it matter which 16 rims as they are on vectra alloy rims at the moment Depends which braking system you have. J60 or J67. I think the 1.4 has J67 braking system, so you'll need the wheels for that. 205/55/r16 is the wrong size for 16" Astra wheels though. They should be 205/60R16, so with a reduced side wall profile the speedo will over-read slightly. There are also insurance implications to consider as well, having the wrong sized tyres fitted. The following info is copied from another site. For Astra J 5-door hatchback, Sports Tourer and 4-door notchback with 1.4, 1.6, 1.4T and 1.3CDTi engines (J67 braking system): PCD 5x105 (distance between neighbouring bolts is 61.7mm), centre bore 56.6mm 16" wheels: 6½J x 16 offset 39, tyre 205/60R16 |
correct spare wheel | livo | 5 | 3,153 |
1:st-Mar-2023, 08:28:05 Last Post: Rusty2009 |
What are the specs for the wheel studs on a 2010 Insignia Sports Tourer? | i.rosca | 0 | 8,494 |
10:th-May-2018, 06:36:09 Last Post: i.rosca |
Spare wheel for GTC Ltd Ed | neilll | 3 | 9,336 |
5:th-Oct-2016, 09:24:07 Last Post: neilll |
Spare wheel size for 1.7 z17dte ecoflex | rbull51 | 2 | 9,026 |
26:th-Jul-2016, 16:52:44 Last Post: rbull51 |
Wheel PCD and offset? | kyleuk2015 | 6 | 7,822 |
19:th-Oct-2015, 12:10:26 Last Post: kyleuk2015 |
Steering Wheel VXR emblem | JohnL | 9 | 13,606 |
1:st-Sep-2014, 16:15:04 Last Post: tucpal |
