windscreen front
front windscreen
Hi anyone else on here have trouble with the front screen freezing on the inside, also after i have defrosted it and left it i e to go to work when i return i have puddles of water on dash running down over glovebox area my vauxhall dealers says that is normal never had a wet dash in any other car ive owned. i have no water anywere getting in ive checked all the usual places, doors boot etc etc. also doesnt happen all the time.
I would check for water in the car common places is the passenger footwell and the boot.
Also check the doors don't have water them in then (if there are rubber bungs in bottom of doors remove them).
That's a common Vauxhall answer because to me they just don't want to find the issue, which could a bad seal etc.
Depending on what model year you have there was also an issue with the passenger side wiper which would allow water into the passenger footwell. also a weak seam weld in the rear.
here what you saying about vauxhall, they had it for a week and said no issues at all , yet when i send them photos of the dash they say thats normal, ive checked doors and boot, all good will look at wiper area tomorrow, problems is doesn't happen all the time .
water on the dash is certainly not normal, however water on the inside of the windows is usually a sign of a water leak somewhere in the car, could be in the boot area ?
I would check the wiper as mentioned by Rusty
I would do a water test. If u have a hose leave it on a slow run on your windscreen for 5 - 10mins and then move onto the door edge and see if any water collects. If the inside of your windscreen froze it could be that the ice melted and caused water but again if your saying "puddles" it may not nlbe that as I would have thought it would of melted that much.
You may need to keep a journal. That notes the weather and what your seeing in regards to water, that will help u to figure out when it happens etc. Just keep it in your car
(3:rd-Feb-2019, 11:09:47)everson38 Wrote: I would do a water test. If u have a hose leave it on a slow run on your windscreen for 5 - 10mins and then move onto the door edge and see if any water collects. If the inside of your windscreen froze it could be that the ice melted and caused water but again if your saying "puddles" it may not nlbe that as I would have thought it would of melted that much.
thanks for your help guys done a few checks but no further forward, cant see water getting in anywhere, will try upload some photos.
Do you have the windows open often, in my cars i try to have the windows open for the last part of the journey, and down a crack when de misting windscreen to allow the moisture out
I have a post on here about leaks somewhere and misting windows, I managed to cure mine it's brilliant now.
https://www.vxoc.org.uk/forum/Thread-mis...1#pid47421
  Retrofit front parking sensors (GTC) pedroc1999 3 2,388 27:th-May-2023, 23:46:17
Last Post: M.Duman
  Lowering springs identify front rear martinpe68 1 1,722 12:th-Sep-2021, 15:22:37
  Front PDC wiring diagram milozic 1 2,496 2:nd-Feb-2021, 09:33:19
  Front suspension knock????? Sri~mike 10 8,147 22:nd-Dec-2020, 10:21:36
Last Post: M222RJF
  Replace windscreen washer bottle cap ma444 1 1,872 4:th-Oct-2020, 07:51:42
  VXR Front Bumper onto a 5dr Bear 2 3,386 3:rd-Oct-2020, 11:48:59
  2017 GTC Limited edition - Front wheel noise Nathan191210 4 2,670 12:th-Jul-2020, 07:37:10
  Gtc 2017 1.4t 120 front brake disc size Nathan191210 2 2,821 25:th-Apr-2020, 07:41:05
  Can You Add Front Fogs to an Astra J? SAMW98SO 2 3,749 10:th-Apr-2020, 13:29:58
Last Post: SAMW98SO
  No sound on indicators, seat belt warning and quiet front parking sensors mpotsb 4 7,440 22:nd-Feb-2020, 19:24:53
Last Post: mpotsb
