sound flapping driving when
Flapping Sound when driving.
Hello Everyone,
I do have an Hatchback Astra J 2015 1.4NET with auto transmission.
I did detected a flapping noise like as you are driving something stick on the tires or it sounds like there is some lines on the road and you are passing on them.
I know it's a very low chance find this kind of a sound issue without hearing it but I'm out of ideas to tell to service to check.
So I made below checks and fixes:
- When I first noticed the sound I re-balanced the summer tires on the tire shop, summer tires are balanced off the car and back tires are balanced again on the car.
- One month ago I switch to winter tires sound increased become more noticeable also balance work is done again. Also asked to check the rims if there is any bend parts but there isn't.
- I was low on front discs and pads so they all changed, back discs and pads seems fine for now.
- While the car is on lift I turned them to hear any problem with the hub bearings , also asked service guys to check them and they didn't hear or find any problem.
- Sound can be heard at best 6th gear 2500 rpm - 3000 rpm  in between 100 Km/h ~ 140 Km/h. Over or under these ranges probably continues to do but I can't hear it over the engine sound.
- I did try applying brakes a bit while keeping the speed to feel if any vibration increase or decrease. Nothing significant there...
- Hard on corners increase the sound and make it more hearable with a higher pitch.
- I put it to neutral while going (I know, not good idea for the a/t) but still hear it the noise.
I'm thinking may be problem is with the hubs bearings may be I need to check on load, but how? (all factory hubs at the moment no change or after market hub installed)
Also may be I need to check alignment settings for wheel camber & caster but when I leave steering alone for test it goes straight at the speeds that I hear the sound.
[url=https://blog.firestonecompleteautocare.com/alignment/alignment-settings-wheel-camber-and-caster/][/url]More scary thoughts... May be problem is caused by diff or gearbox, I don't think it's the engine since when in neutral it continues  also I want to believe it's not gearbox.
So if anyone have another opinion or something else to check, I would be very very appriciated...
Happy new year...
Regards.
could be the diff bearings ?
  No sound on indicators, seat belt warning and quiet front parking sensors mpotsb 4 13,852 22:nd-Feb-2020, 19:24:53
Last Post: mpotsb
  Water sloshing sound Marc_81 6 8,797 29:th-Nov-2018, 12:22:12
Last Post: Maxniomi
  Astra J Infinity Sound problem abba34 9 12,441 11:th-Mar-2017, 17:59:21
Last Post: abba34
  Oscillating Light Rumble when driving at 70mph Vx-Mad-G 3 7,016 26:th-Oct-2016, 21:57:52
  Headlights Levelling Sound sheppy1 2 5,969 11:th-Apr-2016, 12:27:35
  Sound Proofing pope30 6 9,115 23:rd-Jan-2015, 07:29:37
