my astra oil for best opel
Best oil for my Opel astra
Hi all
I have Opel Astra j gear box af40, what is the  best oil for this gear box ??
Manny tenx
I'd advise genuine GM oil.
If your car is 1.4 then you have Gm 6t40 gearbox and it uses dexos 6. AF40 gearbox is used in diesel and you can use GM oil as Rusty suggested. Part number gm 93165147
  astra j shock on standard vs lowered sport chassis obsidian 1 3,311 19:th-Apr-2025, 19:19:09
  Astra J manual – pedal box gone? pretty expensive! Mr Writer 5 17,332 9:th-Sep-2021, 14:27:28
Last Post: Gav-Astra
  weird motor sound Astra J 1.4 turbo oliv.cleiton 2 5,273 18:th-Jul-2021, 08:17:49
  Astra A17DTF - Timing Belt or Chain? everson38 1 4,444 17:th-Jun-2021, 12:03:07
  Astra j mirrors Kiel0777 2 4,374 15:th-Apr-2021, 20:34:53
Last Post: Kiel0777
  Astra won't start after some sensor cleaning? momoomar 2 6,799 3:rd-Oct-2020, 02:04:44
Last Post: momoomar
  Astra J 1.6 A16XER (115 hp) 2010 Outer Belt (and perhaps Timing Belt, too Acond 1 7,735 14:th-Aug-2020, 14:35:21
  Changing Rear Shock Absorbers. Astra-J Hatch. Replace or reuse bottom bolts? Big Dave2 5 12,930 22:nd-Jun-2020, 11:35:40
  Astra J 2011 1.7Cdti Juddering in higher gears Mark72 6 10,939 10:th-Jun-2020, 10:08:54
Last Post: Mark72
  Astra 2.0cdti dpf regen info? Boroboy 19 35,580 5:th-May-2020, 14:22:14
Last Post: Kiel0777
