0)
Threads: 9
Thanks Received:
0 in 0 posts
Car: 2013 Astra 2.0 CDTI Auto Tourer
I'm looking for a OBD2 scanner to find and delete engine management (or service vehicle soon) codes on my Astra.
I have so far tried the Autophix OM 123. It connected with my car ok, but failed to read a service vehicle soon fault displaying on my dash.
Can anyone recommend something that works for them, please ?
0)
Threads: 6
Thanks Received:
0 in 0 posts
2
Car: 2013 Sport tourer 1.7 CDTI (96kw)
for reading and erasing fault codes on Opel (Vauxhalls), i always highly recommend the OP-COM clones.
cheap, pretty reliable! All you need is a laptop with a USB port running windows. (20-40quid)
I personally use a GM MDI clone, also (around 100quid). Good for reading out fault codes, testing modules and clearing fault codes.
However it is not recommended to program with these.
Retrofitted:
0)
Threads: 9
Thanks Received:
0 in 0 posts
Thanks for your replies. I was hoping to find something that I could keep in the car to use if I needed it. The reason being, my car has went into limp mode (undriveable) twice in the two years I've had it - both times leaving me stranded at the roadside with the display telling me the engine has overheated, when, of course it hadn't. Doesn't give me much confidence in the car.
The last time it happened an auto engineer cleared the fault and found it was reading exhaust gas temperature too high.
4)
Thanks Received:
4 in 4 posts
The problem with alot of these cheaper scanners and one's you can keep plugged in is they they don't really work 99% of time they won't even pull error codes and the other 1% I would question if it's giving the correct error code.
