additional usb dash on plugs
additional USB plugs on dash
Does anyone have installed additional USB plugs on dash near or instead of cigarette lighter (or in other place)? if you do have it done, can you share some pics and some tips?
i am thinking of having 3 port USB hub connected to Android head unit and have extensions (something similar into the ones from below URLs) comming to center panel with fixed plugs. not sure if that will even work though.. but USB hubs are quite cheap (don't see the reason for usb 3  at least for testing if this would work at all.
round one (which i believe should fit into cigarette lighter hole, if you would decide to remove it for what ever reason)
square one (i like this little bit more, but there is not much to choose from it appears)
I have a dual usb fitted in both the front and rear power sockets. Fitted an additional power socket for the air compressor for the tyres.
Like this one but dual and only cost 8 quid. http://www.ebay.co.uk/itm/263023754480
Past 2008 Civic 1.8 Type S
  Centre dash speaker extremly quiet, pawex 0 6,011 28:th-Aug-2020, 23:39:47
Last Post: pawex
  dash board speaker cable Qaranc 5 14,061 3:rd-Jan-2020, 23:01:03
Last Post: Qaranc
  Dash cam on Android unit robk999 2 12,622 2:nd-Nov-2019, 10:30:30
