led lights rear
rear led lights
I'm in the same boat as a previous owner, new 2017 gtc which im looking to buy is on the forecourt  with the older rear lights, want dealer to fit the led versions, so is it a matter of getting the lights and the wiring kit and just fitting, or is there something else needed.
(7:th-Jun-2017, 22:25:52)twinpipes Wrote: I'm in the same boat as a previous owner, new 2017 gtc which im looking to buy is on the forecourt  with the older rear lights, want dealer to fit the led versions, so is it a matter of getting the lights and the wiring kit and just fitting, or is there something else needed.
You don't need to change the wiring, its just a simple case of swapping the clusters....Its whether the Break light warning on the dash bothers you.
You can either simply ignore the error (i do that), getting opel/vauxhall to change the VCI or purchase the Happy light show plug in to cancel the warning.
Personally I wouldn't get the Dealer to do it, they will charge you a hours work just for undoing 8 screws & swapping the clusters.
Buashei (18:th-Dec-2025, 15:37:42), N0madd_builds (4:th-Mar-2026, 11:51:29)
