removal expansion tank coolant
Coolant/ Expansion Tank Removal
Hi guys.
I had a quick look around but can't seem to find anything about removing the tank (has a crack and is leaking).
Anybody that could help? Does the battery have to come off?
Thanks in advance
The battery doesn't need to come off.
There is a metal clip on the right at the top which needs to be pulled off.
Then you need to lift it up and pull forward.
  gearbox removal wayne0065 0 3,826 2:nd-Apr-2020, 17:24:00
Last Post: wayne0065
  How to front and rear brake pads removal 5Door Rusty2009 39 59,317 12:th-Aug-2019, 10:55:52
cpeter53 (19:th-May-2025, 12:48:30), Mgrosu67 (13:th-Aug-2025, 21:22:07)
