14
22:nd-Feb-2014, 14:02:24
(This post was last modified: 16:th-Apr-2015, 22:12:04 by tucpal.)
There are some good and some bad options out there for the DRL bulbs
i will cover the best options here.
....The Standard DRL bulbs.....
As you will all know are yellow and Dull
and not really up to the job of being a DRL
what more can i say apart from they fit good and that is about it.
W21/5W (580).
.....PROLARG/MTEC......
The first white looking bulb and cheapest option here
are the cheap Prolarg or MTEC DRL bulbs you find on ebay etc
they go by many names but all are around the £7.99 to £12.00 range.
These are the cheapest option out there
and you do get a nice white light that are also error free
but the down side is they don't fit well at all
and they have been know to fall out of the DRL holder and in to headlight
and it is a bumper off and headlight out job to get the bulb back out
so if you do go for this option be warned
You get what you pay for.
......PIAA..........
By far the best option here is the PIAA DRL BULBS
There are two types the standard Blue PIAA DRL,S.
And then the more expensive mirror PIAA DRL,S.
the PIAA are a bit brighter than the cheep Prolarg DRL,s
and have a bit more wattage but this has no ill effects at all (580) T20 27/8W.
and they are more expensive starting at around £20 for the standard Blue PIAA DRL,s
and around £30 for the mirror PIAA DRL.s they also are error free.
The only real difference is that the mirror PIAA DRL bulb does not look as blue in the headlight
when you look at it as it has a mirrored finish so the blue bulb does not stand out as much.
The fit of the PIAA is perfect and they hold in the DRL holder as well as the standard bulb
and they will not fall out of the holder like the cheaper eBay DRL,S tend to do
They are well worth the extra money for this reason.
......Next LED DRL,s....
If you have an Astra GTC or VXR then you have the option of the LED DRLS
and they will be error free as the DRL on the GTC and VXR are not on the bulb check
so just put the LED in the holder and job done.
But they only work with out errors in the GTC and VXR.
The Astra J 5 door will get error codes from the LED DRL,S unless load resisters are added to cancel the errors
check the how to section for further info on this under Astra j LED DRL.
http://www.vxoc.org.uk/forum/Thread-HOW-...a-J-5-door
They are by far the brightest option here brighter than the PIAA
they also fit very well in the bulb holder
and go for around £20 to £30 for a good set
but you must find a set that will dim down and not all LED bulbs will do this you need a W21/5W 5050 7443 LED
i recommend the LED DRL,s from HIDS DIRECT
for both the Astra GTC and VXR and the Astra j as they will Dim down for side light mode
and they are very very white with a slight tint of blue.
http://www.hids-direct.co.uk/r580-w21-5w...air-white/
...FACTORY.LED....
Then there is the factory LED DRL option
they come with AFL and LED DRL halogen headlights
if you go down this wrought then the LED DRL halogens headlights are needed
but you must also fit the factory LED ballasts to cancel errors
also if these are not fitted there is a real risk of fire
but as yet we dont have a how to on this and this will also be the most expensive option here
All the above options are much brighter and whiter than the standard yellow factory DRL,S
and i prefer the LED DRL,s myself but the PIAA are also very good.
if you have any info or need any help with fitting DRL,S or any other bulb
then check the lighting how to section out for more info etc.
http://www.vxoc.org.uk/forum/Forum-Lighting-How-to-s
Or just post your question here in this thread
and it should get answered.
Thanks Received: 4 in 4 posts
26:th-Feb-2014, 08:48:52
(This post was last modified: 29:th-Jan-2015, 22:14:28 by tucpal.)
tucpal Wrote:the first and cheapest option is the cheap prolarg DRL bulbs you find on ebay
for around £7.99
these are the cheapest option and you do get a nice white light
and have been know to fall out of the holder in to head light
I've fitted these to 62 plate and I've not had a problem they fit tight and haven't fallen out.
I did fit them in a 60 plate and the fitment was lose, I made the connection tight by using a screw driver to bend the connectors in in the housing, and that solved the problem.
Threads: 1
1
I have the LED DRL in my GTC, and they look stunning, but they do make the main lights look a bit yellow. Not so bad at night, they just seem to all merge together!
Threads: 57
Rusty2009 Wrote:I've fitted these to 62 plate and I've not had a problem they fit tight and haven't fallen out.
was the 60 plate mine by any chance mate lol.... is that why i get the warning on the dash lol
Lewis6317 Wrote:was the 60 plate mine by any chance mate lol.... is that why i get the warning on the dash lol
Yes it was yours mate, I think they have changed something from the pre-facelift to the facelift as I don't get any errors yet almost everyone with pre-facelift gets errors.
Threads: 212
I would recommend the mtec ones from hids direct, have used them in all 3 of my astra js, bright white, cheap, no errors, spot on!
Threads: 1
Good thread. Here's the difference between the OEM DRL to the blue PIAA one:
Also, I think even those make the headlights look yellowish, not just LED DRLs (don't know if you can see in this picture):
14
as well as the PIAA DRL i upgraded the head lights to phillips extreme vision h7 bulbs
they match the PIAA very nicely and are much brighter and whiter than the standard bulbs.
14
7:th-Mar-2014, 19:56:42
(This post was last modified: 1:st-Feb-2015, 01:20:24 by tucpal.)
Here are a few pictures of my light set up
PIAA DRL in DRL mode.
PIAA DRL in side light mode.
PIAA DRL AND PHILLIPS extreme vision H7 main lights
Threads: 12
Would highly recommend the PIAA's...I've fitted the blue ones and to be honest you cant really see the blue unless you are looking for it...one of lads at work has fitted the cheaper bulbs into a 62plate corsa and at the side of mine they are not as white or any where near as bright...mine have been fitted for nearly 6months with no issues...one tip I would give to anyone changing the DRL bulbs is buy some 45 deg long nose pliers from Ebay for about £4.00, job done in 5mins flat compared to half hour a side, a lot of swearing and scraped knuckles
14
I have updated and added more info etc to the above post on the DRL,S.
just to bring it a bit more up to date.
Threads: 1
1
Car: Astra J
19:th-Feb-2016, 07:23:48
(This post was last modified: 19:th-Feb-2016, 07:26:14 by Jerry.
Edit Reason: URL added
To share some pictures
Before I fitted factory LED DRL headlamps I tried with China LEDs.
Link:
http://www.aliexpress.com/item/7443-7440...7781abd522
LED vs. Halogen
SideLight
Poslano z uporabo Tapatalk
Threads: 57
Car: Astra J SRI 2.0 CDTI
(19:th-Feb-2016, 07:23:48)Jerry Wrote: To share some pictures
Link:
LED vs. Halogen
SideLight
Poslano z uporabo Tapatalk Did they dim when you turned on the sidelights?
Threads: 1
1
Car: Astra J
19:th-Feb-2016, 08:12:14
(This post was last modified: 19:th-Feb-2016, 08:20:46 by Jerry.)
Yes, but in my opinion not enough.
With main beam they are still to bright. I think.
You can estimate yourself.
Threads: 19
Car: Astra J Vx-Line
Link:
LED vs. Halogen
SideLight
So did you fit the factory headlight units with LED as standard? Did you not get any errors, and did you have to install the factory ballasts?
Threads: 57
(19:th-Feb-2016, 08:12:14)Jerry Wrote: Yes, but in my opinion not enough.
Poslano z uporabo Tapatalk Brighter than the headlight!
Threads: 1
1
Car: Astra J
(19:th-Feb-2016, 08:30:51)Nemo Wrote: (19:th-Feb-2016, 07:23:48)Jerry Wrote: To share some pictures
Link:
LED vs. Halogen
SideLight
So did you fit the factory headlight units with LED as standard? Did you not get any errors, and did you have to install the factory ballasts? The ballast is built-in the headlamp no problems with that.
Currently I added load resistors but searching for better solution.
Threads: 19
At least you've got the factory headlights though
Threads: 0
Car: Astra j 1.7 cdti
I bought some cheap drl bulbs off eBay and fitted them but now I get the error message about checking bulbs ? If I buy the PIAA ones will that solve the problem , also will they fit a 60 plate Astra j properly because the cheap ones were a poor fit ? Thanks in advance
14
Threads: 0
Car: Astra J GTC
For almost a year I use bulbs 5x Led Cree. On the left and on the right Cree light bulb with a blue filter similar to PIAA.
Threads: 11
I have fitted some LED bulbs in my astra J as posted on another forum and are working error free without load resistors but don't dim down in sidelight mode. Even so, looking promising with no errors, hopefully some dimmable ones will be found soon.
Threads: 57
(22:nd-Mar-2016, 08:57:59)bannan Wrote: I have fitted some LED bulbs in my astra J as posted on another forum and are working error free without load resistors but don't dim down in sidelight mode. Even so, looking promising with no errors, hopefully some dimmable ones will be found soon.
Sent from my SM-G900F using Tapatalk They aren't MOT passable if they don't dim when you put them into sidelight mode
Threads: 11
I know. That's the problem unfortunately. Hoping to find some others that do dim but don't flag up a check bulb message. I played about with the pins and managed to get them to dim but can't remember if it brought up a message.
Threads: 9
13:th-Apr-2016, 23:01:41
(This post was last modified: 13:th-Apr-2016, 23:03:54 by stigeye.)
Courtesy of info gained from this thread, just put these in our car... W21/5W T20 DRL bulbs WHITE Polarg M13 £5.95 inc free delivery for two on eBay
Nice and white in the day, gone are dull yellow, and at night they could probably work as headlights lol.
Threads: 19
Car: Astra j 2.0 cdti sri vx line
are these the right chrome ones?
Threads: 12
Car: Astra j
(13:th-Apr-2016, 23:01:41)stigeye Wrote: Courtesy of info gained from this thread, just put these in our car... W21/5W T20 DRL bulbs WHITE Polarg M13 £5.95 inc free delivery for two on eBay
Hey dude by any chance you know which ones you got for this? And how was the reliability?
Cheers connah
Threads: 2
Car: Vauxhall Astra 1.4 turbo
Hi buddy.... would these fit a 13 plate q.4 turbo Sri? I'm picking it up Friday!!
Threads: 0
Car: 2013 Astra GTC 1.4T SRi 140
I got some LED DRL bulbs from Hids direct and they work great and dull down for sidelights and when headlights are on!
Threads: 0
Car: Astra Elite
(8:th-Oct-2017, 15:47:00)mark_b_uk Wrote: I got some LED DRL bulbs from Hids direct and they work great and dull down for sidelights and when headlights are on!
Just been reading some of the reviews for HID Direct and a lot of them say terrible company to deal with.
Threads: 2
Car: Astra GTC 2.0 CDTI
Threads: 3
Car: 2016 GTC Sri 140ps
I have a 2016 GTC the DRL are yellow in colour and as stated a bit pathetic, so if I am reading it right I'm able to just straight swap for LED bulbs no drilling no resistors etc. Is this the case sorry for the noobish question.
Simon
Threads: 0
Car: Astra J GTC
A year ago I installed Osram LED W21 / 5W LEDriving 6000K. 6-year warranty and zero problems so far.
Threads: 3
(13:th-Jul-2018, 10:04:48)janpat1970 Wrote: A year ago I installed Osram LED W21 / 5W LEDriving 6000K. 6-year warranty and zero problems so far.
Just ordered these hope they look as good as yours!
Threads: 0
Car: Vauxhall Astra J
(17:th-Jul-2018, 17:26:21)simsgtc Wrote: (13:th-Jul-2018, 10:04:48)janpat1970 Wrote: A year ago I installed Osram LED W21 / 5W LEDriving 6000K. 6-year warranty and zero problems so far.
Just ordered these hope they look as good as yours! Do you get any error messages with these LED? I have tried others before and get constant messages. I have a Vauxhall Astra J
Threads: 0
Car: Astra J Sri
any link? Can only find ones with the 2 level brightness not 3
Threads: 7
Car: Astra GTC 2.0CDTI SRI
(2:nd-Aug-2018, 11:31:07)F3NTN Wrote: (17:th-Jul-2018, 17:26:21)simsgtc Wrote: (13:th-Jul-2018, 10:04:48)janpat1970 Wrote: A year ago I installed Osram LED W21 / 5W LEDriving 6000K. 6-year warranty and zero problems so far.
I’ve found these on Amazon, but they have a “d” at the end of the code instead of “q”.
Just be aware that there are a lot of Osram fakes around.
Osram 7905CW 02B Premium Retrofit LED Light, Set of 2 https://www.amazon.co.uk/dp/B01LXZJEG1/r...yBb8C5A964
I’ve just bought these from Lush Lighting City.
Hope this helps?
Threads: 0
Car: Astra J Sri
What are the ones you bought like? Any good?
Threads: 7
(3:rd-Aug-2018, 13:45:44)F3NTN Wrote: What are the ones you bought like? Any good?
Yeah they’re very good, looks just like in the picture.
I’ll try to take a picture later when it’s gone dark
Threads: 0
Car: Astra J Sri
Threads: 7
(3:rd-Aug-2018, 15:46:20)F3NTN Wrote: Magic, cheers!!
Just bear in mind that if you have an Astra J not a GTC, you will have to check they’ll still be error free
Threads: 7
Believe it or not but this is just with DRL’s on!!!! It’s taken on my phone but I think it shows they’re bright. I’ll take a day time picture in the morning if it’s not too sunny
Threads: 7
Daytime shot
Threads: 0
Car: Astra J Sri
Threads: 0
Car: Astra J Sri
These don't work properly on 5 door J's...
Threads: 0
Car: Astra J GTC
W21 / 5W positioning Osram + Philips Crystal Vision Ultra. The phone is lying. The reality is more yellow.
Threads: 2
Car: Vauxhall Astra GTC 2015
Just fitted these DRLs to my 2015 GTC SRi.
They look really good in daylight - really white.
https://rover.ebay.com/rover/0/0/0?mpre=...2022372933
I also got these headlight bulbs and they’re an almost perfect match to the DRLs. I’ll see how well they perform in darkness later tonight.
https://rover.ebay.com/rover/0/0/0?mpre=...2633607134
I’ll post pictures later on once it’s dark!
Thanks to everyone who has posted previously and given advice. I collected the car yesterday and think it’s a great machine! Managed to retro fit the Bluetooth unit today. It’s working perfect. Also tested the rear parking sensors which I’m getting fitted by a professional cos I don’t want to mess things up (though I’m sure I could do it!). The sensors are working fine alongside the OEM stereo.
Threads: 7
Car: Astra Sports Tourer 2.0 CDTI SRI
As a lot of these posts are quite old now and things may have changed, has anyone successfully installed LED DRL bulbs to an Astra J (not a GTC) with no error's and no resisters needed? I'd really like some nice white bulbs but don't really want to be messing around adding resistors.
thanks,
Marc
Threads: 3
Car: Astra j Sport Tourer
I don't think so.
You can put bulb like PIAA or cheaper one.
But LED will give you error.
Threads: 7
(25:th-Oct-2018, 07:49:40)Dooks Wrote: I don't think so.
Thanks for the reply. Are the PIAA bulbs nice and white? Really don't like the yellowness at the minute.
