options fin shark
Shark fin options
So I'm wanting a shark fin aeriel, not bothered about being gm, I just don't want to loose signal quality, is this possible??.
no as the shark fin has nothing to do with the radio only satnav
i am yet to see an aftermarket one that works for FM
tucpal Wrote:no as the shark fin has nothing to do with the radio only satnav
Couldn't I remove the fm mast? Coil it around the boot and just fit a shark fin?
nope rusty has been looking at some options but they are not cheap
Cam if you want one that won't lose much in the way of signal you are looking at £70-100+.
Calearo seem to have the best rep.
You also have to be careful as the curve on the roof will cause some problems for a large on you want to try and keep within the Factory fitted size.
Here are a couple I'm looking at.
http://www.calearo.com/ita/automotive-af...677937.php
http://www.calearo.com/ita/automotive-af...677940.php
Might come in handy for those with an FM rear window mount.
http://www.calearo.com/ita/automotive-af...562005.php
  Bluetooth Streaming Options? D4NNYB0Y 1 3,591 12:th-Sep-2021, 15:33:35
  GTC exhaust options johno1412 1 4,775 12:th-May-2021, 14:26:49
  Stereo upgrade options Amazingusername 6 14,184 9:th-Feb-2021, 14:07:41
Last Post: loeb
  Best drl options j and gtc. tucpal 56 58,810 16:th-Mar-2019, 10:34:40
  Replacement Shark Fin Telsun 12 10,209 21:st-Jan-2019, 18:18:17
  Adding menu options??? Amazingusername 3 6,764 27:th-Jan-2018, 13:37:47
  Shark fin for cd400 chrisb2511 10 36,291 10:th-Aug-2016, 07:21:51
  Shark Fin sheppy1 17 15,235 21:st-Apr-2015, 20:40:14
  Hidden Options sheppy1 4 9,146 14:th-Apr-2015, 19:50:41
  Wheel options 18 19 20 what do you think ? DE5IRED 21 24,651 3:rd-Aug-2014, 19:33:01
Last Post: Cameron UK
