mode smd vxr conversion
VXR mode SMD conversion
Guys,
Ive changed the SMDs on the instrument cluster to have a blue under vxr mode and it wont change over to blue. All the connections are fine and when connected a multi meter to the LED's they all light up?
Has anyone else achieved this or is it something that i should have done...
Oli
Go over all the solder joints.
(11:th-Jan-2017, 22:33:22)Rusty2009 Wrote: Go over all the solder joints.
thank you for the quick reply Rusty. Will check again tomorrow. Does it switch over all the LEDs at once? because when the VXR button is pressed not even the white lights go out
Operator error
turns out the sport back light was off under the menu where ive had the dash stripped
  Vxr led backlight conversion to Normal GTC Afus1987 2 4,042 27:th-Apr-2017, 09:10:44
Last Post: thebigman1106
  engineering menu returns to default mode Saxito@Tech 0 3,241 1:st-Apr-2017, 19:54:43
Last Post: Saxito@Tech
