biturbo grill from front
Front grill from biturbo
Hello, i`d line to change my standard front grill and install the grill from the biturbo.
I have this one http://i.ebayimg.com/00/s/OTYyWDE2MDA=/z...wHQ9WZYQY/$_1.JPG
And I want this one http://i.ebayimg.com/00/s/OTYwWDEyODA=/z...wRJ9XgLiz/$_1.JPG
I found some part numbers, you can check here http://nemiga.com/cat_spares/epc/opel/p10/b1/13/
It seems to me that i'll need just the number 18 from the link above. Do you think that i'll need the number 16 too? Is number 16 and 19 the same for the two grills?
There will be most likely a size difference in the grill
and it may not fit there was on the 5 door biturbo front grill
you are best to see one in the flesh and measure it or ask someone to do that for you
  Retrofit front parking sensors (GTC) pedroc1999 3 2,406 27:th-May-2023, 23:46:17
Last Post: M.Duman
  Lowering springs identify front rear martinpe68 1 1,740 12:th-Sep-2021, 15:22:37
  BiTurbo spacers eatmybogbrush 0 1,086 9:th-Jun-2021, 03:06:46
Last Post: eatmybogbrush
  Front PDC wiring diagram milozic 1 2,515 2:nd-Feb-2021, 09:33:19
  BiTurbo timing belt Craig2305 3 2,083 5:th-Jan-2021, 08:25:01
  Front suspension knock????? Sri~mike 10 8,224 22:nd-Dec-2020, 10:21:36
Last Post: M222RJF
  Astra BiTurbo solenoid buzzing again.... eatmybogbrush 2 2,145 14:th-Nov-2020, 12:26:58
  VXR Front Bumper onto a 5dr Bear 2 3,399 3:rd-Oct-2020, 11:48:59
  2017 GTC Limited edition - Front wheel noise Nathan191210 4 3,095 12:th-Jul-2020, 07:37:10
  BiTurbo Rear Bumper Dudderz 3 2,499 5:th-Jun-2020, 19:49:44
