Trade Count:
1)
Threads: 52
Thanks Received:
0 in 0 posts
Thanks Given: 0
3
Car: 2.0 CDTI SRi Astra J
Sex: Male
Total Feedback: 0
After installing the heated leather seats I'm encountering a few issues that I'm hoping are an easy fix!
First is the heater controls, drivers side stays on forever once pressed but the passenger side goes off after roughly about one minute..
The lumbar support works fine on both seats.
The seats don't seem to be heating up properly, I can feel that my seat heats up a little bit but being on full power is of thought you'd feel a noticeable heat..
I've not sat in passenger seat yet but it doesn't seem to warm up either, also if I put it on to number 2 heat it stays on forever!
Any help and advice is appreciated!!
Tonto
Trade Count:
4)
Threads: 359
Thanks Received:
4 in 4 posts
Thanks Given: 1
69
Sex: Male
Total Feedback: 0
They have cut-out point which seems to work only when on level 3 which will cut the seat out.
Trade Count:
2)
Threads: 220
Thanks Received:
0 in 0 posts
Thanks Given: 0
14
Sex: Male
Total Feedback: 0
it will be the head unit most likely set up for left hand drive.
Trade Count:
0)
Threads: 200
Thanks Received:
0 in 0 posts
Thanks Given: 0
6
Car: Astra J 1.7 CDTI
Sex: Male
Total Feedback: 0
28:th-Nov-2016, 20:14:57
(This post was last modified: 28:th-Nov-2016, 20:15:55 by sheppy1.)
Nahhh can't see it being down to head unit! It's not that smart, all of does is display config which the standard head unit would have displayed... It won't add config functionality that reverses how the heated seats work!
Just change the setting in the hidden menu anyway which puts the door opening icon etc. The correct way around
Trade Count:
4)
Threads: 359
Thanks Received:
4 in 4 posts
Thanks Given: 1
69
Sex: Male
Total Feedback: 0
But if it's not display the correct door opening it would point to it being set to LHD is there no setting?
Trade Count:
0)
Threads: 200
Thanks Received:
0 in 0 posts
Thanks Given: 0
6
Sex: Male
Total Feedback: 0
And your doors still show as wrong way around when opened? The option is a little confusing so you sure you selected the correct one?
Trade Count:
1)
Threads: 52
Thanks Received:
0 in 0 posts
Thanks Given: 0
3
Sex: Male
Total Feedback: 0
No doors show the correct way around now. But windows are still wrong.
Trade Count:
0)
Threads: 3
Thanks Received:
0 in 0 posts
Thanks Given: 0
0
Car: 2012 Astra J Elite 1.6
Sex: Male
Total Feedback: 0
I have the same tonto in my elite with the M072 unit. The display for the drivers heated seats shows on the passenger side and vice versa. But that doesnt change the function of the buttons for me in anyway they heat the correct sides, just the unit displays them on the wrong sides. Ive checked all in the settings for the unit but again I think its part of the window display issue.
