mode amp tri 6ch
6ch tri-mode AMP
Does anyone know if there are any 6 channel tri-mode amps?
Been looking all over and can't find any any where.
The high frequency speakers will not load the amplifier below 150 hertz and the low frequency speakers will not load the amplifier above 150 hertz. In the real world, the point where the high and low pass speakers stop being a load on the amplifier is not as abrupt as this and there is actually an overlap of frequencies where both high and low frequency drivers are a load (albeit an ever decreasing load) on the amplifier. There is no single point in the audio spectrum where both the high frequency and low frequency drivers present their rated impedance to the amplifier.
  H5754 Recovery mode mrwup 0 2,626 27:th-Feb-2018, 11:27:37
Last Post: mrwup
MrDjArMz (22:nd-May-2023, 18:02:47)
