p24ac fault cdti 7 code 1
Fault Code P24AC 1.7 CDTI
I have a 2011 Astra J 1.7 CDTI 96 kW A17DTF ecoflex and one Fault Code P24AC.
EGR Valve is fine. And also EGR Cooler Bypass Solenoid Valve.
There are no power problems with the engine.
If I reset the P24AC, after some minutes it is set again and I get the message "Service Vehicle Soon"
Where does this Fault Code come from.
I found in Internet only "P24AC EGR Cooler Coolant Pump Feedback Circuit Low"
But I think my Astra does not have a EGR Coolant Pump.
Maybe somebody could help me.
Stephan
Have you checked out the fault code thread?
It's hard to read your post in tapatalk as it looks like you've copied and pasted.
  EBC Pads and Discs (15% Off Code) M222RJF 2 5,416 9:th-Sep-2020, 01:13:11
Last Post: M222RJF
  Cambelt - 2.0 CDTI, 2011 Vx-Mad-G 9 12,465 25:th-Mar-2019, 08:15:54
