lights interior
Interior Lights
Quick question, I changed my interior lights to LEDs a few weeks ago, now I'm sure when I used to unlock the car/open the door all 3 of the front lights would come on aswell as both of the rear, now I'm getting both the rear and just the centre one on the front panel.
Am I imagining things here or should all 3 of the front light up?
Have you checked to ensure they are in the correct way around or checked to see if they work manually by flicking the switch on the roof to turn them on?
I believe all mine come on when unlocking the car and also when opening the doors
(11:th-Jun-2016, 21:47:48)sheppy1 Wrote: Have you checked to ensure they are in the correct way around or checked to see if they work manually by flicking the switch on the roof to turn them on?
Definitely work off the button first thing i checked buddy
Hmmmm very odd! The switch in the middle position too?
(11:th-Jun-2016, 21:53:17)sheppy1 Wrote: Hmmmm very odd! The switch in the middle position too?
Yes mate, I thought it was the blue leds I put in but popped the whites back in and still the same
Huh... Odd! I'll have to test to confirm if mine do the same
Cheers mate would appreciate it
(11:th-Jun-2016, 21:02:56)tommyboy1289 Wrote: Quick question, I changed my interior lights to LEDs a few weeks ago, now I'm sure when I used to unlock the car/open the door all 3 of the front lights would come on aswell as both of the rear, now I'm getting both the rear and just the centre one on the front panel.
The lights on our car are exactly the same. As far as I'm aware, of the 3 lights in the front, only one in the middle is a courtesy light, this comes on when you enter/ exit the car. The other two are reading lights that come on when you press the buttons.
As stigeye says, only the middle one lights up. The outer two work on the button
(12:th-Jun-2016, 00:54:23)bhalay207 Wrote: As stigeye says, only the middle one lights up. The outer two work on the button
Cheers chaps must of been imagining it then
Haha I imagined it too then! Got your answer though
  Happyblue module ambient lights Kdun 1 4,874 9:th-Mar-2019, 10:22:32
  New member - Led lights HarryH 7 8,202 4:th-Jan-2019, 13:55:53
  Astra J GTC Daytime running lights Wanna_be_dj 5 11,853 1:st-Jun-2018, 09:49:33
Last Post: Wanna_be_dj
  Ambience lights gtc Wullie1967 0 3,804 10:th-Mar-2018, 10:24:05
Last Post: Wullie1967
  Astra GTC ambience lights Wullie1967 2 5,832 9:th-Mar-2018, 19:14:13
  Unlocking with lights on Mspencer 10 12,074 21:st-Jan-2018, 20:32:19
Last Post: Hummelshøj
  No wiring for the interior boot light marcus01 5 8,863 20:th-Dec-2017, 16:48:23
Last Post: rlievens
  Licsence plate lights Nathjnz 2 5,783 11:th-Dec-2017, 16:37:25
Last Post: Nathjnz
  Auto Lights Breengin 8 9,196 11:th-Nov-2017, 21:17:42
Last Post: umognog
  Help day time lights andiman t 8 9,566 22:nd-Sep-2017, 07:08:53
Last Post: andiman t
