unit options head
Head Unit Options
So I have done a little bit of digging around for options regarding replacing head units etc.
ICEBOX M072 with DAB and aerial approx. £400
Retrofit DAB to CD400/400+ approx. £200
Aliexpress MTK3360. approx. £200
Aliexpress "Kanor" approx. £370
Aliexpress RFG7002 approx. £180
Aliexpress Q7882A approx. £250
None of the Aliexpress units list DAB as an option though.
IceboxAuto has at least 2 other units as well for the astra J. C072 and another one which is about 100 quid cheaper
Have anyone tried this one ??
http://www.iceboxauto.com/vauxhall-astra...d-51-a5754
/Michael
(1:st-Sep-2016, 22:38:00)mdruedal Wrote: Have anyone tried this one ??
/Michael
No but when I asked the guy who owns icebox auto about whether that one was better or the M072 he said this
"Hi Dayle, my honest opinion is the M072 is still a better unit. The factory who make them, the internals, processors etc are always better. Our data shows, firmware from the factory of 5.1 is given out more than the M072 to resolve little bugs. Always fixed i may add.
My preference, Id stick with M072, graphically, the OS looks more pleasing to the eye."
/Michael
Ok, I ordered the 5.1 Android model already, I have an Eonon aftermarket model now, which did not fit very well into the 2-DIN frame (or actually I think it was the frame that was not made to the standard I reckon), so I wanted to go for an model that was made specifically for this car instead.
I read the whole thread through regarding the M072, but decided to go for the newer Android version, also I liked the design better without the SD card reader next to the screen.
Will be interesting to see when I get the device, should be an easy install.
/Michael
post some info about it when you haveit on the car please
some photos/videos would be appreciated
(8:th-Jun-2016, 15:56:30)GOKIWI Wrote: So I have done a little bit of digging around for options regarding replacing head units etc.
I just fitted the Drive Audio unit. Satnav, Bluetooth , ipad/iphone interface, reverse camera, dvd player, cd player, usb interface, etc. Cheaper from Car-Vision.co.uk  who will do the entire package for about £600 - and fit it for you for free if you prefer. DAB is extra.
https://www.car-vision.co.uk/vauxhall-na...20232.html
Just seems absurdly expensive considering you can get the M072 unit for 300 which does all that same stuff plus runs Android apps
I couldn't even put on here what I think of car vision!
I was just reading down this thread and thought Russell would be biting his lip if he saw that post and then I got down to the last post lol.
/Michael
ok, I got the unit yesterday, installed it quickly this morning, I will post some pictures later on.
To those of you who are using the M072, can you adjust the volume with the CD300/CD400 buttons ??
All those buttons are not functional right now, maybe I forgot to connect some wire..
Another thing I miss, which I can see others have with the M072, is the USB converter, that plugs right into the stock USB socket in the Astra J.
Yep you can use ALL the factory buttons without issue. And so you didn't get the extension cable then?
(15:th-Sep-2016, 17:30:46)sheppy1 Wrote: Yep you can use ALL the factory buttons without issue. And so you didn't get the extension cable then?
I did not receive any USB extension cable, that fits into the Stock Astra J USB socket... and maybe I missed some wires, since the factory buttons do not work.
  How To Fit Sub To CD400 Head Unit TUFFKNUX 138 177,861 20:th-May-2021, 09:19:58
Last Post: h4r7y
  How to Install aftermarket head unit Rusty2009 55 84,185 14:th-Mar-2021, 15:16:56
Last Post: GTC-Nut
  Battery drain Android tesla style head unit rayvo1 4 7,709 9:th-Sep-2020, 21:05:31
Last Post: rayvo1
  Dash cam on Android unit robk999 2 12,346 2:nd-Nov-2019, 10:30:30
  CD400 buttons not working Android head unit install mephisto 4 12,080 27:th-Oct-2019, 17:30:00
Last Post: mephisto
  Bluetooth Aux options??? Schiffers 6 6,486 14:th-Oct-2019, 16:27:24
Last Post: Schiffers
  Astra SRi CDTI VX Line - CD400 Upgrade options AdaKer 3 7,082 13:th-Aug-2019, 06:48:28
  How to Install Android Head Unit + Wireless Reverse Camera sheppy1 64 69,003 9:th-Jan-2019, 15:07:53
Last Post: Shorty5
  after market head init marky79 0 6,947 4:th-Nov-2018, 17:17:12
Last Post: marky79
  Where to find standard head units cubez0 9 13,822 18:th-Oct-2018, 17:55:45
