s light fog
Fog Light's
So Doris doesn't come with fog lights (there's a black plastic insert below the indicator), can these be retrofitted and does anybody have a part number ?.
Found this not sure if it's what I am after
http://www.ebay.co.uk/itm/VAUXHALL-ASTRA...Sw3mpXFdN0
Hey! I actually retrofitted fogs to my car too... Mines a face-lift model though... Not sure what yours is? I was told that only fogs from a face-lift model will fit a face-lift model.
Anyway.. You're gonna need the fogs and surrounds, the bulbs obviously and wiring between the BCM and the front fuse box too... Then you're gonna need someone to programme it all.
All in it cost me around £250 and had to have custom wiring made up by @Rusty2009 and programming done by vauxhall (@Rusty2009 can do that too).
Oh that's a bummer (programming/custom wiring looms) - All of a sudden this isn't an attractive option anymore, I'm used to my Seat having tall these things as standard.
Yeah it's a pain really as most things need either one or the other or sometimes both!
TBH unless you really want or need them... I wouldn't bother! If it's for looks then you could always just buy the fogs and surrounds and install them and just don't wire or programme them... You won't fail and MOT or anything like that with them in that state
  Tail light cover callyross 4 5,584 9:th-Mar-2020, 08:21:47
2015 Gtc reverse light Elad1962 2 4,591 18:th-Jun-2019, 17:06:49
Last Post: vocky
  courtesy light jj120979 5 7,599 19:th-Jun-2017, 10:40:12
Last Post: jj120979
  Third break light/High level break light VK91 3 10,864 3:rd-Jan-2016, 22:18:03
Last Post: cornishtaz
  Light sensor warning! Alienbv 9 13,294 12:th-Mar-2015, 15:30:35
  Indicator/Fog Light Replacement sheppy1 12 14,144 11:th-Mar-2015, 08:50:55
