led lights wing fitted mirror
LED wing mirror lights fitted
Just finished wiring in my LED puddle/wing mirror lights.
Ran two core flex from the interior light down the A pillar, behind glove box, through door loom, took the mirror off & ran the wire along side the electric mirror loom.
Only thing is I ordered a black strip but they sent white so I'm gonna order more black and swap it over.
Works great, sorry for the terrible video
http://youtu.be/8bhso25KDs8
Il try get some pics tomorrow when I do the drivers side.
Well done
Might change the led strip for something drilled & screwed in but at least I've got the wiring there now so only 2 bolts holding the mirror on to change it
trial and testing is the best way to find the correct way
So is that literally stuck on?
(6:th-Feb-2016, 22:38:35)Nemo Wrote: So is that literally stuck on?
The current LED strip is held on with 3m tape then wired into the interior light yep.
Any plans to cut a hole and fasten them in?
I'm going to try a few different LEDS to see which combination of light and fitting is best. I'm happy with the stick on ones as you can't see them unless you look up from underneath but something flush/fitted more OEM is more my preference. The concept is great though!
Yeah I'd like a proper fitting if I were to do it, I like the concept though, good work
Very well done!
Finished it today
Basically follow the how to on puddle lights thanks to Rusty but then run the wire from the door loom up and out of the wing mirror part of the top of the door.
Drill a small hole for the wires to go through in the bottom of the mirror, pop the cap off and feed it though. You'll need to feed it through the same place the loom goes which is the hardest part but can be done. I then taped this to the mirror loom to keep it OEM and tidy.
[Image: E088BFCF-94D6-4BDB-AD8A-574DF4F43D1B_zpsgdddex1u.jpg]
[Image: CBBE2A07-7238-46ED-A5F6-43D22CA8AD2C_zpszzvfoys9.jpg]
You can see the hole at this angle..
[Image: 2A804C70-F732-4DAA-AD09-006A7A151578_zpswajdnv7r.jpg]
To keep the water out I have used something called trim shield which I use at work as a windscreen fitter to stop scuttle panels rattling etc. It's like a black industrial blu tac which seals the hole.
Finished.. The eager eyed ones will noticed I messed up by cutting my black strip too short meaning only 3 lights worked so I have used white for now.
[Image: 4360973E-5AFE-4B7B-A078-1C4B63C5D682_zpstc5o9hxb.jpg]
Finished...
[Image: 95BF6A58-A0C7-4861-99D2-6EAFFC6DDDBE_zpsdv7pywq1.jpg]
[Image: 41B19FF8-778D-481C-99FF-012F5918B2DB_zpsjv2hnstt.jpg]
I'm really happy with it as you literally can't see the strips unless you look up from underneath.
Well done mate!
  auto fold mirror modules Qaranc 4 2,185 11:th-Jan-2023, 01:49:50
Last Post: Qaranc
  New AutoDipDown module for passenger mirror A20DTH 2 1,992 21:st-Oct-2022, 09:33:44
Last Post: rlievens
  perm 12v near mirror dammfust 1 1,546 6:th-Sep-2021, 11:31:25
Last Post: Astragtc1282
  Mirror Flick19191 7 5,253 11:th-Nov-2019, 11:58:51
Last Post: Flick19191
  Happyblue module ambient lights Kdun 1 2,638 9:th-Mar-2019, 10:22:32
  New member - Led lights HarryH 7 4,410 4:th-Jan-2019, 13:55:53
  Astra J GTC Daytime running lights Wanna_be_dj 5 6,626 1:st-Jun-2018, 09:49:33
Last Post: Wanna_be_dj
  Ambience lights gtc Wullie1967 0 2,625 10:th-Mar-2018, 10:24:05
Last Post: Wullie1967
  Astra GTC ambience lights Wullie1967 2 3,526 9:th-Mar-2018, 19:14:13
  Unlocking with lights on Mspencer 10 7,155 21:st-Jan-2018, 20:32:19
Last Post: Hummelshøj
