Trade Count:
( 0)
Threads: 5
Thanks Received: 0 in 0 posts
Thanks Given: 0
0
Car: Vauxhall Astra J Excite 1.6
Sex: Male
Total Feedback: 0
Is the parking sensors from an astra estate the same as the hatchback?
Whats the best way to spray them? Is there a company that does it.
Trade Count:
( 2)
Threads: 220
Thanks Given: 0
14
Sex: Male
Total Feedback: 0
Trade Count:
( 0)
Threads: 5
Thanks Given: 0
0
Sex: Male
Total Feedback: 0
(22:nd-Jan-2016, 15:34:34)tucpal Wrote: There the same
Cool, Thank you.
Trade Count:
( 0)
Threads: 5
Thanks Given: 0
0
Sex: Male
Total Feedback: 0
22:nd-Mar-2016, 16:05:12
(This post was last modified: 22:nd-Mar-2016, 16:23:03 by AlexFitton.)
I have bought these parking sensors for my retro fit.
http://www.ebay.co.uk/itm/391264040971?_...EBIDX%3AIT
Do i need a bracket to fit them to my car as they appear to be the flush mounted ones. Also how would i go about spray painting them?
I found the answer but i cant seem to find where to buy them from. I cannot see them on autovaux.
20 14 54 005 BRACKET, SENSOR, REAR, RH, OUTER 0
20 14 54 007 BRACKET, SENSOR, REAR, RH, INNER 0
20 14 54 004 BRACKET, SENSOR, REAR, LH, OUTER 0
20 14 54 006 BRACKET, SENSOR, REAR, LH, INNER 0
Trade Count:
( 2)
Threads: 220
Thanks Given: 0
14
Sex: Male
Total Feedback: 0
yep you need brackets try autovaux
Trade Count:
( 0)
Threads: 5
Thanks Given: 0
0
Sex: Male
Total Feedback: 0
22:nd-Mar-2016, 20:27:25
(This post was last modified: 22:nd-Mar-2016, 20:29:34 by AlexFitton.)
(22:nd-Mar-2016, 20:07:42)tucpal Wrote: yep you need brackets try autovaux
I tried that autovaux part number and searching the site but i found nothing.
Il either have to phone them up or i will just keep looking for a different part number and searching again.
You wouldnt happen to know what the bolt was for the steering wheel either would you?
Trade Count:
( 2)
Threads: 220
Thanks Given: 0
14
Sex: Male
Total Feedback: 0
Trade Count:
( 4)
Threads: 359
Thanks Received: 4 in 4 posts
Thanks Given: 1
69
Sex: Male
Total Feedback: 0
(22:nd-Mar-2016, 16:05:12)AlexFitton Wrote: I found the answer but i cant seem to find where to buy them from. I cannot see them on autovaux.
Put them part numbers in online, you will be best of getting a body shop to drill the holes and bond them on.
Unlike the kit Tucpal linked you to those brackets are what they would use at time of manufacturing the bumper whereas the one's in the kit are designed to clip together.
Trade Count:
( 0)
Threads: 5
Thanks Given: 0
0
Sex: Male
Total Feedback: 0
(23:rd-Mar-2016, 08:29:19)Rusty2009 Wrote: (22:nd-Mar-2016, 16:05:12)AlexFitton Wrote: I found the answer but i cant seem to find where to buy them from. I cannot see them on autovaux.
I have emailed autovaux to see if they can help me.
I cannot find the brackets anywhere on the internet.
Trade Count:
( 0)
Threads: 5
Thanks Given: 0
0
Sex: Male
Total Feedback: 0
23:rd-Mar-2016, 17:38:14
(This post was last modified: 23:rd-Mar-2016, 17:39:10 by AlexFitton.)
Spoke to autovaux these should he the correct part numbers however they dont have them on the site so fingers crossed the correct ones.
12777468 BRACKET, SENSOR, REAR, RH, OUTER 0
13294648 BRACKET, SENSOR, REAR, RH, INNER 0
12777466 BRACKET, SENSOR, REAR, LH, OUTER 0
12777467 BRACKET, SENSOR, REAR, LH, INNER 0
Trade Count:
( 0)
Threads: 3
Thanks Given: 0
0
Total Feedback: 0
How do you connect to the sensors?
Don't you need the factory wiring loom with plugs?
Trade Count:
( 4)
Threads: 359
Thanks Given: 1
69
Sex: Male
Total Feedback: 0
(27:th-Apr-2016, 09:03:07)THEHITMAN Wrote: How do you connect to the sensors?
Yes factory loom or if you can find all the connectors and pins you could make your own loom/s
