speedo
Speedo
Looking for a bit of info. Thinking of having a go at swapping out the leds in the speedo but just wanted to know if i got a second-hand one of ebay would i be able to do the led conversion and then just fit it back into mine, and would it work?
Short answer is no as it's programmed to the car
Well thats a bit *****. Didn't fancy having a go on my own speedo just in case it goes pete tong.
If you want to pop to Swindon I could do it for you
Will keep that in mind and give you a shout the next time i travel down to pompey.
Yes as Baz said coded to car, as long as the part numbers match and it's been divorced from the car tho it can easily be programmed to your car.
Baz, what white LEDs would you recommend for the speedo display?
I've not done a white conversion on the speedo yet but I've git these to try
http://pages.ebay.com/link/?nav=item.vie...85&alt=web
You may find them very dull Baz in daylight same make I got for the centre display and you couldn't see it in daylight, fine at night tho.
Cheers chaps
Users browsing this thread:
