Trade Count:
( 2)
Threads: 220
Thanks Received: 0 in 0 posts
Thanks Given: 0
14
Sex: Male
Total Feedback: 0
21:st-Feb-2014, 19:21:15
(This post was last modified: 16:th-Apr-2015, 21:47:51 by tucpal.)
This is a How for Factory DAB and Integrated FM and Shark Fin Ariel.
for the CD400 with out the Rear Glass Already in Place.
If you have The NAV500 or 600 Go to the How to for The NAV500/600.
So if you have the CD400 Follow Here...
The first thing you are going to have Get is the Tail Gate from a car that has DAB
it will have to be Complete with Looms in Place and not Cut
As all the Looms will be Needed to Swap Over to your car
The Receivers for FM and DAB will also be Swapped as well as the Glass.
By far the best way is to Buy the Tail Gate in Good Condition and the Same Color and Just Swap it over
At around £250 Complete Is about the Wright Price for that so its the More Expensive option Here.
the Tail Gate that i got the Panel was Damaged so i got the Lot for £75
Plus £50 to Swap the Glass from the Tail Gate to may car.
You can just Skip the Glass and Tail Gate
If you want and just Buy a DAB and FM roof Mast Ariel
but again there not Cheep and for a Good one there around the £100 mark,
if you do go with this Option just skip the First part and follow the rest.
STEP ONE..........
Get a Tail Gate and Remove the Glass first
i found a friendly Local Mobile Glass Fitter and got him to Remove the Glass first
as most of the Looms that are needed are Clipped in Behind the Glass
so you can not get them out Complete with the Glass in Place
i called him back when i had Swapped the Looms over to Refit the Rear Glass to my car
when i had everything in Place.
Note this is the Main Connector from the Tail Gate to the Body Loom
the rear washer Hose also Joins up here and must also be Disconnected
it just Pulls out and Pushes back in but be Careful it does not Leek when Refitting
its best to Remove the Interior Boot Trim to get Access to the Location
off this Connector just above the Fuse Box in the Boot
follow the FLEX floor Thread for Trim Removal.
STEP TWO...........
These are the Tabs you will need on the New Glass for the FM and DAB Receivers.
STEP THREE.........
This is the (FM Suppressor ZA) and Connects up in between the Heater Matrix.
STEP FOUR........
This is the (FM Module ZK) the Black Fakra Z Cable 1 meter
And goes to the (FM Receiver MA) at the Top of the Glass
The white Fakra z Cable 2 meters will go too the
Existing Female End of the FM Ariel Cable in the roof
that you unplug from the old Roof Mast Ariel.
STEP FIVE.........
This is the (FM Rreceiver MA).
STEP SIX.........
This is the (DAB Receiver ZR)
A 5 meter fakra z Cable Female to Female
will run from here to the front Module.
STEP SEVEN........
Both the farkra z Cables will run Through the Right Hand Side Gator on the Tail Gate
One to the DAB Module
And one to the FM Cable.
This is the old FM Cable unplug it
And Reconnect the new FM Cable from the Glass.
You can now Remove the old Roof Rast Ariel
And Throw it away as this now has no use
the FM will now work from the Rear Glass
so you can now put the Shark Fin on top
this has no Function apart from Looking Good.
That's the FM all Working now.....
This is the Point were you can now Follow
if you went for the DAB FM Roof Ariel Option..
You will need a 5 Meter Fakra Z
Female to Female Cable
one end will go to the Roof Mast Ariel
Or the (ZA receiver) on the Rear Glass
This Cable will go to the Front off the Car
And Come out very Near the Bonnet open Catch
in the front Drivers Foot Well
If you have a feel just Behind the Trim Behind the Bonnet Open Catch
you will Find a Blue Male Double fakra Connector.
One side will go to the DAB Module and one side is Blank
Join the Double Female End to the Double Male.
Place The single fakra Z Male End to the Female 5 meter Cable from the rear
the small Wire in the Photo below is not Needed.
You can now fit the DAB Receiver
Located just above the Bonnet open Catch.
You will find the Green Connector and the Black Connector
just above the Accelerator Peddle
Connect both too the Module
the Module is held in Place by a Bracket and one Screw
Your are now Ready for Programming and VCI codes.
The DAB will now Work,
DAB Module Part Numbers are
for the (Astra J 13319590 UBT.)
and for the (GTC 13362385 UBT.)
The Cradle for the DAB unit Part Number is (GM 13263525.)
Trade Count:
( 2)
Threads: 220
Thanks Given: 0
14
Sex: Male
Total Feedback: 0
i am still in the process of this retro fit i have every thing now in place
i just need the module and programming done now
so i will up date when i get it all done and up and running
Trade Count:
( 2)
Threads: 3
Thanks Given: 0
3
Car: Vauxhall
Sex: Undisclosed
Total Feedback: 0
I have DAB fitted as an option but don't have the shark fin ariel. Does this mean the normal Ariel is pointless or there for FM reception?
If for show could you show how to remove the Ariel and replace with shark fin.
Trade Count:
( 2)
Threads: 220
Thanks Given: 0
14
Sex: Male
Total Feedback: 0
there are a few different options for the way the FM will be received
ether from the standard Ariel on the roof
or from the rear glass this option will be for the cd500 etc
as they use the shark fin for satnav.
so in your case you have the DAB but you get the FM from the roof
you need to check a few things but yes it will be possible to get the FM
from the rear glass
first do you have all the tabs in place on the rear glass
and also check to see if the FM Ariel on the roof is attached to a cable
check them and come back here.
Trade Count:
( 2)
Threads: 220
Thanks Given: 0
14
Sex: Male
Total Feedback: 0
thinking about this your best option as i take it you use your DAB more than the FM
rusty found an FM Ariel that attaches to the heater matrix
and was cheep you could go down that route
Trade Count:
( 4)
Threads: 359
Thanks Received: 4 in 4 posts
Thanks Given: 1
69
Sex: Male
Total Feedback: 0
tucpal Wrote:thinking about this your best option as i take it you use your DAB more than the FM
In the end mate I had to go back to a roof mounted one as every time I went though trees etc I lost signal not good at all.
I want the full rear window setup you have, I'll have to come and nick your's lol..
Trade Count:
( 2)
Threads: 3
Thanks Given: 0
3
Car: Vauxhall
Sex: Undisclosed
Total Feedback: 0
Trade Count:
( 2)
Threads: 220
Thanks Given: 0
14
Sex: Male
Total Feedback: 0
looking at that you have the bottom FM receiver there
so now you are going to have to remove the trim
and see what is behind there
you may just be missing the top receiver and a farkra cable
if that is that case it will be very cheep for you do to this
you may be missing the receiver marked MA.
Trade Count:
( 2)
Threads: 3
Thanks Given: 0
3
Car: Vauxhall
Sex: Undisclosed
Total Feedback: 0
Thinking about it I can't see me using the FM much.
How easy is it to switch to a shark fin?
I've found a non functional one on eBay.
Just want it for looks really but want to be able to swap it back if I sell it down the line.
Also thinking of painting the Ariel same colour as the car before fitting.
Trade Count:
( 2)
Threads: 220
Thanks Given: 0
14
Sex: Male
Total Feedback: 0
i will have a genuine shark fin for sale in the next few days.
can you use the DAB with out the FM if so
as you say do you need FM
Trade Count:
( 2)
Threads: 220
Thanks Given: 0
14
Sex: Male
Total Feedback: 0
the one i will be selling will work for FM as i converted it
but the single is not grate
but it is a GM genuine shark fin
Trade Count:
( 2)
Threads: 3
Thanks Given: 0
3
Car: Vauxhall
Sex: Undisclosed
Total Feedback: 0
I might be interested mate.
How easy is it to fit.
Trade Count:
( 2)
Threads: 220
Thanks Given: 0
14
Sex: Male
Total Feedback: 0
9:th-Mar-2014, 18:24:53
(This post was last modified: 16:th-Apr-2015, 21:47:27 by tucpal.)
3 minutes max disconnect the farkra cable remove 1 10mm bolt from Ariel base and that's it
it is a one of a kind i made it my self by swapping the circuit from an a mast Ariel
and converting it in to the shark fin.
as i say it does work but will get a bit of static now and again
its no perfect but it does work
but as you use the DAB it would be perfect for you
and you wont lose the FM.
Trade Count:
( 2)
Threads: 220
Thanks Given: 0
14
Sex: Male
Total Feedback: 0
20:th-Mar-2014, 18:22:36
(This post was last modified: 31:st-Jan-2015, 19:28:32 by tucpal.)
latest update i now have the DAB module
so everything is now in place and all connected up and all wired up for the DAB and FM retro fit
i only need the programming done now.
and then all will be working.
Trade Count:
( 2)
Threads: 220
Thanks Given: 0
14
Sex: Male
Total Feedback: 0
22:nd-Mar-2014, 20:26:14
(This post was last modified: 31:st-Jan-2015, 19:27:32 by tucpal.)
all the programming was done today
for the DAB retro fit and all works 100% better than the FM
i can totally recommend this retro fit
the sound quality is much better worth every penny.
Trade Count:
( 0)
Threads: 11
Thanks Given: 0
0
Total Feedback: 0
Just out of curiosity can you fit DAB without the Sat navigation?
Trade Count:
( 2)
Threads: 3
Thanks Given: 0
3
Car: Vauxhall
Sex: Undisclosed
Total Feedback: 0
Yes, I have DAB with the CD400
Trade Count:
( 0)
Threads: 11
Thanks Given: 0
0
Total Feedback: 0
Was it a complicated retrofit?
Trade Count:
( 2)
Threads: 3
Thanks Given: 0
3
Car: Vauxhall
Sex: Undisclosed
Total Feedback: 0
Mine was fitted as a factory option.
[MENTION=16]vxmods[/MENTION] does the retrofits, check out his page here
Trade Count:
( 2)
Threads: 220
Thanks Given: 0
14
Sex: Male
Total Feedback: 0
30:th-Jul-2014, 21:53:22
(This post was last modified: 4:th-Apr-2015, 08:55:59 by Rusty2009.)
Trade Count:
( 0)
Threads: 11
Thanks Given: 0
0
Total Feedback: 0
Thank you both, kind of want to get this done rather than a thought in my head.. fm is a thing of the past lol
Trade Count:
( 2)
Threads: 220
Thanks Given: 0
14
Sex: Male
Total Feedback: 0
Yes it sure is the cheapest way to get this done is to find a tail gate complete it will save you lots of £ I am sure Vxmods can also help but you will need the glass for sure
Trade Count:
( 0)
Threads: 11
Thanks Given: 0
0
Total Feedback: 0
I will look into this maybe not straight away but defo on the to do list, how much money we talking?
Trade Count:
( 2)
Threads: 3
Thanks Given: 0
3
Car: Vauxhall
Sex: Undisclosed
Total Feedback: 0
Not sure how much the DAB module is but eBay is best shout for a rough price or contact VXmods.
Also depends if you want to keep the FM signal and run it through rear window, if so you will need the correct glass. correct glass or not. I did some research into it a few weeks ago. I already have the correct window and I was looking at around £120 for the remaining parts.
Trade Count:
( 2)
Threads: 220
Thanks Given: 0
14
Sex: Male
Total Feedback: 0
the glass is the hard part i got the complete hatch glass and all receivers for £75 as the boot was damaged £25 to swap the glass over £50 for the module
and about £25 on cables and i got the programing for free when i had the satnav done
it can be done cheap you've just got to get lucky and find the correct hatch
look for a shark fin on a car that is braking then you know it will have all parts on there
Trade Count:
( 0)
Threads: 11
Thanks Given: 0
0
Total Feedback: 0
Good advice guys, I will look into this further and do some research gather up part numbers and get on the case pronto
Trade Count:
( 2)
Threads: 220
Thanks Given: 0
14
Sex: Male
Total Feedback: 0
31:st-Jul-2014, 11:34:20
(This post was last modified: 4:th-Apr-2015, 08:58:05 by Rusty2009.)
i PUT SOME PART NUMBERS AND INFO FOR THE FM BITS HERE
http://www.vxoc.org.uk/forum/Thread-Rear-window-FM
AND HERE IS THE DAB RECEIVER FOR THE WINDOW ALSO
http://www.ebay.co.uk/itm/Vauxhall-Astra...3ce1dc24d1
gtc dab module here
http://www.ebay.co.uk/itm/Vauxhall-Astra...3cd8c498ec
but none about for the 5 door but they may have different part numbers but i don't know if they are the same
Trade Count:
( 0)
Threads: 1
Thanks Given: 0
0
Sex: Undisclosed
Total Feedback: 0
Would a DAB module from another car work or are they locked? I know the stereo would need coding to activate DAB just wondering if the modules had a security setting/device.
Trade Count:
( 2)
Threads: 220
Thanks Given: 0
14
Sex: Male
Total Feedback: 0
No mate I used a used one no problems at all from a insignia as long as the part number is correct then a used one will work
Trade Count:
( 0)
Threads: 57
Thanks Given: 0
4
Car: Astra J SRI 2.0 CDTI
Sex: Male
Total Feedback: 0
4:th-Jun-2015, 10:56:07
(This post was last modified: 4:th-Jun-2015, 10:57:49 by bhalay207.)
Is this the right fakra cable I need?
http://pages.ebay.com/link/?nav=item.vie...22&alt=web
Is there any other cabling that I'll need?
Trade Count:
( 2)
Threads: 220
Thanks Given: 0
14
Sex: Male
Total Feedback: 0
what are you using as an Ariel
Trade Count:
( 0)
Threads: 57
Thanks Given: 0
4
Sex: Male
Total Feedback: 0
I'm going to go for an aftermarket roof ariel
Trade Count:
( 2)
Threads: 220
Thanks Given: 0
14
Sex: Male
Total Feedback: 0
ok mate can you send a picture of the connectors on the Ariel
then i can be sure what you need is it FM and DAB and i take it you have a CD400
Trade Count:
( 0)
Threads: 57
Thanks Given: 0
4
Sex: Male
Total Feedback: 0
I've not got it yet, I'm in the planning stage and gathering an idea of what I need. I'll be looking into something like what @rusty2009 has just fit. I've also found another alternative
http://www.dabonwheels.co.uk/SharkFin_DA...erial.html
Or
http://www.dabonwheels.co.uk/Kinetic_DRA...erial.html
Trade Count:
( 4)
Threads: 359
Thanks Given: 1
69
Sex: Male
Total Feedback: 0
@bhalay207, forget the that shark fin utter rubbish and doesn't work (I have two of them in the junk box).
The mast is like my old one.
If you want a mast mine will be for sale once I take pics.
Trade Count:
( 0)
Threads: 57
Thanks Given: 0
4
Sex: Male
Total Feedback: 0
That's surprising, as the website gave it a good review. Does your mast do DAB? What did you make to it? To be honest, I'm not overly fussed on the shark fin. Even though it would like good, I'd rather have spot on signal.
Trade Count:
( 4)
Threads: 359
Thanks Given: 1
69
Sex: Male
Total Feedback: 0
Yes mate it has DAB & FM, it was good mate I only ever got one dead spot with it (which I don't get with the fin).
Trade Count:
( 0)
Threads: 57
Thanks Given: 0
4
Sex: Male
Total Feedback: 0
Let me know when you're getting rid then and I'll be interested!
In this case can you let me know what wiring I'll need. I've got a standard CD400
Trade Count:
( 2)
Threads: 220
Thanks Given: 0
14
Sex: Male
Total Feedback: 0
thanks for sorting it out cheers rusty
Trade Count:
( 4)
Threads: 359
Thanks Given: 1
69
Sex: Male
Total Feedback: 0
6:th-Jun-2015, 10:02:04
(This post was last modified: 6:th-Jun-2015, 10:03:02 by Rusty2009.)
Trade Count:
( 1)
Threads: 16
Thanks Given: 0
0
Car: 2.0 CDTi Elite
Sex: Male
Total Feedback: 0
Hey all
Has anyone else looked near their pedals for the black and green connectors and not found them? If so what can I do?
Trade Count:
( 4)
Threads: 359
Thanks Given: 1
69
Sex: Male
Total Feedback: 0
Every car I've come across has them.
Trade Count:
( 2)
Threads: 220
Thanks Given: 0
14
Sex: Male
Total Feedback: 0
I have head of one that did not but most do have them
Trade Count:
( 1)
Threads: 16
Thanks Given: 0
0
Car: 2.0 CDTi Elite
Sex: Male
Total Feedback: 0
Right I have had my car in bits today lads in an effort to find these cables!
http://i.imgur.com/Keba5b4.jpg
http://i.imgur.com/LQs58HT.jpg
Can anyone trace theirs and tell me what direction they go? Perhaps mine have slipped behind somewhere over the years?
If not what are my options here, is it possible to buy the cable as a part#? Or am I looking at after market unit setup?
If its the latter, I;m going to have a DAB unit and bracket for sale shortly.... :(
Trade Count:
( 2)
Threads: 220
Thanks Given: 0
14
Sex: Male
Total Feedback: 0
19:th-Jun-2015, 18:06:47
(This post was last modified: 19:th-Jun-2015, 18:07:26 by tucpal.)
it looks like you dont have the two connectors needed the are taped up behind the accelerator pedal
one green and one black the cable runs to the bonnet catch
got a pic for you but not the best
if they are not there you can not do it as they go to the back of the cd400
but if you ask andy from vx mods he will be able to make a loom for sure
let him know i sent you and i will tell him what you need
by the way what year and model is your car as you are the second i know of now
who have not had them there but they are there on nearly all cars
Trade Count:
( 4)
Threads: 359
Thanks Given: 1
69
Sex: Male
Total Feedback: 0
The wires can be added.
Trade Count:
( 2)
Threads: 220
Thanks Given: 0
14
Sex: Male
Total Feedback: 0
19:th-Jun-2015, 18:31:24
(This post was last modified: 19:th-Jun-2015, 18:36:05 by tucpal.)
Do you think you could do it rusty as I know your very good at this sort of thing you don't need the green plug as a fakra z will just go from the back window to the DAB unit just need the plug on the DAB to the back of the CD400
Trade Count:
( 1)
Threads: 16
Thanks Given: 0
0
Car: 2.0 CDTi Elite
Sex: Male
Total Feedback: 0
2011 2.0 cdti Elite with start stop
Any ideas what it might cost to do the loom then?
Trade Count:
( 2)
Threads: 220
Thanks Given: 0
14
Sex: Male
Total Feedback: 0
Rusty is best were are you based
Trade Count:
( 0)
Threads: 27
Thanks Given: 0
4
Car: BMW
Sex: Undisclosed
Total Feedback: 0
I really ought to check mine to make sure I've got it, I have the CD500 Navi with shark fin, but I do have the 'Dummy' wire on my rear windscreen, so whether I need just the box and lead from the screen to the window... or more.. we'll find out lol.
