poor fuel
Poor fuel
Hi guys, all of a sudden I've noticed my fuel range dropping a lot.
For instance, yesterday it said 480 miles drove 30 mile now says 425 and I'm driving sensibly.
Noticed first gear seems sluggish with hesitation then bouncing but other gears work fine.
Wondering if egr is blocked.
I've cleaned it on my old vecci which was easy also cleaned the inlet manifold and eventually cleaned the swirl flaps.
Egr easy to do on the 1.7cdti? Anything else I can try?
sounds like the best thing to do and then see what happens
you can try a good quality DPF cleaner also
http://www.ebay.co.uk/itm/141809892366?_...EBIDX%3AIT
but remember it is winter and lights and heaters on all the time etc
fuel mpg will drop in the winter months.
but a good EGR clean as you say is the way forward
and a good fuel cleaner also helps every 3000 miles
Cheers, Ive used redex in the past and another that I can't remember - the bottle u pour to fill up a little measuring reservoir the twist the top to pour it out, millers I think?
Is the egr easy enough to do? Any special tools required?
Good man @Tucpal that's the best stuff to use.
I need some in mine my MPG has gone down 25 from 42.
the EGR should just bolt off it wont be that much different from the older 1.9 cdti
the next time i do it to my 2.0 cdti i will put a how to up as i need to do my one very soon
but as yet we don't have a how to on that one.
(9:th-Nov-2015, 21:00:48)tucpal Wrote: the EGR should just bolt off it wont be that much different from the older 1.9 cdti
Great cheers bud. On my 2.0ltr vecci tools 20mins to do, was a bit nervous disconnecting the coolant pipes but used pipe clips was a pice of cake.
Be goods see a how to, I've bought a can of that dpf stuff so will try this
I did look up before check the tech section if not I'll look it up again put the info up for you
Found it
http://www.vxoc.org.uk/forum/showthread.php?tid=1447
rusty any info on the 2.0 cdti as well cheers
(9:th-Nov-2015, 21:24:28)Rusty2009 Wrote: Found it
Is that all it is to it? Any coolant pipes to pull off or anything that needs to be removed to do it?
That's all I could find on it the EGR shouldn't have any coolant pipes.
(9:th-Nov-2015, 21:25:57)tucpal Wrote: rusty any info on the 2.0 cdti as well cheers
I shall look tomorrow mate as I want to do mine
Definitely a how to for the egr please fellas @Rusty2009 @tucpal
EGR 2.0CDTI added into my post the other thread
http://www.vxoc.org.uk/forum/Thread-Serv...8#pid17518
rusty any info on the 1.3 DTE.
(12:th-Nov-2015, 12:49:31)sotoskon Wrote: rusty any info on the 1.3 DTE.
I'll have a look later mate.
I've got all 3 print outs on the 1.3 just need to sort them and upload them.
  Threaded Mode Diesel Fuel guage erratic low fuel and then half tank caretaker 1 1,629 30:th-Dec-2022, 17:32:20
  Fuel pump needs priming? Amazingusername 3 1,641 21:st-Mar-2021, 20:34:09
Astra 1.7 CDTI fuel quality problem klajdi 0 2,086 10:th-Sep-2020, 12:10:05
Last Post: klajdi
  ESP service message, erratic fuel range figures on trip computer mpotsb 2 2,772 7:th-Sep-2020, 12:04:29
Last Post: mpotsb
  Fuel Shutoff Valve NuttySqurill 1 1,773 12:th-Aug-2020, 07:58:08
  1.7cdti drinking fuel Hazard10 2 3,072 9:th-Jan-2020, 22:13:15
Last Post: Peckalz
  New Fuel filter. Wont start SALMHAGE 1 2,457 18:th-Dec-2019, 23:24:29
Last Post: SALMHAGE
  How to change Astra j fuel flap mechanism? Amazingusername 2 2,622 11:th-Oct-2019, 12:56:58
Last Post: Amazingusername
  Fuel consumption - 1.3 CDTI mw2299 3 3,737 19:th-Oct-2017, 10:53:43
  2.0cdti ECU update for DPF causing poor fuel & loss of performace Rusty2009 17 15,656 23:rd-May-2017, 07:00:23
