Trade Count:
4 )
Threads: 359
Thanks Received:
8 in 8 posts
Thanks Given: 1
73
Sex: Male
Total Feedback: 0
Does anyone know if these can be changed for the old type that you could adjust with a pin?
Reason is the drivers side always shoots over the car tried adjusting it I can't get any lower, I've also damaged it trying now.
Trade Count:
0 )
Threads: 21
Thanks Received:
0 in 0 posts
Thanks Given: 0
0
Car: 1.7td Elite 2010
Sex: Male
Total Feedback: 0
I made a tool after googling it, identical to the one that Vauxhall sell but even that doesn't adjust them as well as I'd thought. It'd be interested to know if your idea is possible Rusty because its a downfall of the Astra J.
Trade Count:
2 )
Threads: 220
Thanks Received:
1 in 1 posts
Thanks Given: 0
15
Sex: Male
Total Feedback: 0
it all depends if they will fit in the hole on the scuttle panel it is the drivers side that seems to be badly positioned
i found if you take it out and then push it back in but not all the way it will sit lower and the jet will then hit the windscreen perfectly
Trade Count:
4 )
Threads: 359
Thanks Received:
8 in 8 posts
Thanks Given: 1
73
Sex: Male
Total Feedback: 0
I think the new ones are better for motorway driving but round town they are naff.
I did use the tool the dealers use problem is its down as far as it will go.
Tucpal I'd be more worried about it falling out
it would just be luck.
Trade Count:
2 )
Threads: 220
Thanks Received:
1 in 1 posts
Thanks Given: 0
15
Sex: Male
Total Feedback: 0
no it holds fine been like that for a good while now works much better
Trade Count:
2 )
Threads: 220
Thanks Received:
1 in 1 posts
Thanks Given: 0
15
Sex: Male
Total Feedback: 0
it will sit just a few millimeters lower
and then it hits the window and does not fly over the top of the car
the adjuster just will not make the jet go low enough
[video=youtube;lB576YCiRiE]https://www.youtube.com/watch?v=lB576YCiRiE&list=FLWbz_u8PCLgYjRRIrE9CDKA&index=1[/video]
Trade Count:
4 )
Threads: 359
Thanks Received:
8 in 8 posts
Thanks Given: 1
73
Sex: Male
Total Feedback: 0
Nice one mate that looks better.
I have found these's
http://www.ebay.co.uk/itm/VECTRA-C-Carav...27e2370f5b
Not so fussed about the heated part might give them ago once I have some spare funds.
This are from a H they may well fit too
http://www.ebay.co.uk/itm/VAUXHALL-ASTRA...257acc266b
Trade Count:
2 )
Threads: 220
Thanks Received:
1 in 1 posts
Thanks Given: 0
15
Sex: Male
Total Feedback: 0
they are worth a go rusty there is only one way to find out
Trade Count:
4 )
Threads: 359
Thanks Received:
8 in 8 posts
Thanks Given: 1
73
Sex: Male
Total Feedback: 0
Just ordered the H ones above so will let you know once the arrive
Trade Count:
2 )
Threads: 220
Thanks Received:
1 in 1 posts
Thanks Given: 0
15
Sex: Male
Total Feedback: 0
cool it is worth a go
Trade Count:
4 )
Threads: 359
Thanks Received:
8 in 8 posts
Thanks Given: 1
73
Sex: Male
Total Feedback: 0
The H ones fit but I need to get the deflector off so I can clip it in properly.
Trade Count:
2 )
Threads: 220
Thanks Received:
1 in 1 posts
Thanks Given: 0
15
Sex: Male
Total Feedback: 0
Trade Count:
2 )
Threads: 57
Thanks Received:
0 in 0 posts
Thanks Given: 0
0
Total Feedback: 0
nice, be good if it all works
Trade Count:
0 )
Threads: 57
Thanks Received:
0 in 0 posts
Thanks Given: 0
4
Car: Astra J SRI 2.0 CDTI
Sex: Male
Total Feedback: 0
Your not wrong, the washer jets are awful. I questioned whether they sprayed the windows at all!
Trade Count:
4 )
Threads: 359
Thanks Received:
8 in 8 posts
Thanks Given: 1
73
Sex: Male
Total Feedback: 0
19:th-Mar-2015, 13:03:21
(This post was last modified: 6:th-May-2015, 14:06:23 by Rusty2009 .)
Here is a video showing a few different angles for the J & H washer jets needs a little more refinement but overall I much prefer the H ones.
Trade Count:
2 )
Threads: 220
Thanks Received:
1 in 1 posts
Thanks Given: 0
15
Sex: Male
Total Feedback: 0
they certainly hit the window now
Trade Count:
2 )
Threads: 57
Thanks Received:
0 in 0 posts
Thanks Given: 0
0
Total Feedback: 0
They are better
Trade Count:
0 )
Threads: 3
Thanks Received:
0 in 0 posts
Thanks Given: 0
0
Total Feedback: 0
Trade Count:
2 )
Threads: 220
Thanks Received:
1 in 1 posts
Thanks Given: 0
15
Sex: Male
Total Feedback: 0
there the same as the astra j has already
Trade Count:
0 )
Threads: 3
Thanks Received:
0 in 0 posts
Thanks Given: 0
0
Total Feedback: 0
I'll try to adjust them if didnt work ill get the h ones.
Trade Count:
0 )
Threads: 63
Thanks Received:
0 in 0 posts
Thanks Given: 0
1
Car: Astra-K
Sex: Male
Total Feedback: 0
The new corsa has a triple jet each side better than the H, I find my J ones ok
Trade Count:
2 )
Threads: 220
Thanks Received:
1 in 1 posts
Thanks Given: 0
15
Sex: Male
Total Feedback: 0
have you got a link to them baz sounds interesting
i must say i have only really heard 5 door members about the direction of the jets
Trade Count:
0 )
Threads: 63
Thanks Received:
0 in 0 posts
Thanks Given: 0
1
Car: Astra-K
Sex: Male
Total Feedback: 0
No link as only noticed today on my courtesy car.
Will have to do some searching
Trade Count:
2 )
Threads: 220
Thanks Received:
1 in 1 posts
Thanks Given: 0
15
Sex: Male
Total Feedback: 0
Trade Count:
0 )
Threads: 63
Thanks Received:
0 in 0 posts
Thanks Given: 0
1
Car: Astra-K
Sex: Male
Total Feedback: 0
Had a look at the Corsa washers and don't think theyfit the Astra as there fitted to the bonnet
Trade Count:
2 )
Threads: 220
Thanks Received:
1 in 1 posts
Thanks Given: 0
15
Sex: Male
Total Feedback: 0
8:th-May-2015, 16:12:59
(This post was last modified: 8:th-May-2015, 16:13:17 by tucpal .)
a much better location that is for sure
Trade Count:
0 )
Threads: 63
Thanks Received:
0 in 0 posts
Thanks Given: 0
1
Car: Astra-K
Sex: Male
Total Feedback: 0
Unfortunately doesn't look like they can be fitted to our cars
