drl indicators
DRL indicators
I was thinking in work today would you be able to put indicators into the DRL? The main reason I thought this was my mirrors don't have indicators only low down (where fogs are)
not really as there is no way to hold an indicator bulb in the DRL holder hole
the DRL and indicator are also on the canbus check so errors would show if you just removed the DRL
Tucpal is right the bulbs are on the canbus.
Anything is possible if you put your mind to it though I'm still connived the GTC headlamps would fit, but not found a chance to prove/ dis prove this.
  No sound on indicators, seat belt warning and quiet front parking sensors mpotsb 4 13,276 22:nd-Feb-2020, 19:24:53
Last Post: mpotsb
  Side mirrors with indicators Elad1962 3 5,959 5:th-Feb-2019, 07:40:03
  Cascada led indicators Wayneofwolves 15 14,981 5:th-Feb-2017, 14:44:53
Last Post: Wayneofwolves
