wiring info speaker
Speaker wiring info
Speaker wiring info U65/UW4
[Image: Speakers%20%28U65-UW4%29.png]
Speaker wiring info UQA infinity sound system
[Image: Speakers%20%28UQA%29.png]
[Image: Amplifier%20Inputs%20%28UQA%29.png]
Hi Rusty,
I worked on my cable loom and managed to clean it from the complete interioir loom (the one I picked up on a crashed GTC), thanks to the schemes here. Most of the wire's colors are different for a GTC but it was helpfull regarding pin's numbers on connectors.
Here is now an important information for those who want to make the Infinity mod, I clearly see that the red power supply wire, FL and RL speaker's wires pass under the seats, where my seller cut them thinking there was no audio wires at this place Looney I have to extend them.
To explain with the drawing :
- All 8 wires from audio source go to the rear end amplificator (+ 2 shield protection, 1 common yellow/green and 1 remote)
- Then 10 wires from the amp (the 2 wires for central way are now independent) return directly to each speaker.
- Nbr 1 is RearRight you have to remove pins 3 and 4 to the door connector to put yours from Infinity loom. For GTC there is no door connector it's directly the speaker connector, easy.
- Nbr 2 is FrontRight and you have to remove the pins 4 and 5 to the door connector and put pins from Infinity loom.
- Nbr 3 is RearLeft  you have to remove pins 3 and 4 to the door connector to put yours from Infinity loom. For GTC there is no door connector it's directly the speaker connector, easy.
- Nbr 4 is FrontLeft and you have to remove the pins 4 and 5 to the door connector and put pins from Infinity loom.
Splits for tweeters are made on FR and FL wires in the area between Nbr 1 and Nbr 5 (under retractable sheath)
- Nbr 5 is a mid way connector that brings the 8 audio wires (+ shields and so on...) from the source to the amp and also bring back the parallel wires for FR tweeter, Central way, FL tweeter.
On the radio (source) connector side, you will have to remove all the 8 audio pins + shields + remote and put pins from the Infinity loom. The pins are easy to remove : just take off the white part and use a small flat screwdriver to free the pins.
I hope the explanations are not too complicated to understand. I will update when I discover how it's made on the car and how to re-use the wires/pins/connectors already in there ;-)
But I think I'll be blocked at some point because... I don't have a MDI, how can I do to reprog the radio from the crashed GTC ?
  Request heated steering wheel wiring diagram emilalexandrubarb 2 2,952 19:th-Dec-2024, 20:16:39
Last Post: emilalexandrubarb
  Side turning/indicator wiring diagram to help install sequential LED DRL strip. Leady78 0 8,729 11:th-Mar-2021, 17:53:55
Last Post: Leady78
  Wiring up my dashcam. Take power from...? rlievens 14 19,881 29:th-Jun-2019, 20:42:29
  cd400 to cd500 wiring ??? tzr608 12 21,969 15:th-Feb-2019, 18:18:23
Last Post: modoncity
  navi 600 memory card usb aux wiring tzr608 1 12,296 15:th-Aug-2018, 20:22:32
  cd400 wiring pin for 2 aerial amplifiers power tzr608 1 14,937 18:th-Jul-2018, 07:13:42
  Please for help with wiring diagram. kebibg 5 13,925 18:th-Jun-2018, 07:09:16
Last Post: kebibg
  Middle Speaker on 2015 CD400+ srea064 8 15,206 10:th-Sep-2016, 00:11:36
Last Post: srea064
  Middle Speaker on 2015 CD400+ srea064 1 10,382 7:th-Sep-2016, 17:21:07
Last Post: bhalay207
  Electric windows wiring Rusty2009 0 12,226 27:th-Oct-2014, 08:52:18
11 User(s) read this thread:
milozic (30:th-Sep-2025, 20:13:06), kaitsur (29:th-Dec-2025, 08:48:54), obsidian (20:th-Jun-2025, 22:02:16), jas7c5-2008 (30:th-Dec-2025, 21:51:54), Fingerout (18:th-May-2025, 18:14:25), noffczi (6:th-Jul-2025, 18:55:42), ImaoCow (19:th-Aug-2025, 18:31:27), lollone (31:st-Oct-2025, 16:56:56), dc2901 (17:th-Nov-2025, 11:32:56), Jonas Lythje (16:th-Jan-2026, 08:16:25), lar77 (18:th-Feb-2026, 16:41:41)
